Home > Maintenance & Modifications > ** Help before refit new front lights do I keep reflector?
Stacey007
Hello
My new front lights (wipac crystal) have two things I didn't expect.
Built in side light?
Reflector part in front of the new H4 bulb.
My question do I keep this reflector part? I'm guessing keep it but unsure and will refit one side after lunch :
you see one I have taken off and one its fitted....? (the bit on the concrete)
thanks
Post #566218 24th Sep 2016 12:40pm
Keep the reflector on" the side light bulb is up to you, tag it in the side light if you want. I have on mine Thumbs Up
Post #566219 24th Sep 2016 12:44pm
Stacey007
I thought so
Great Thumbs Up
Post #566223 24th Sep 2016 1:07pm
Off on mine, completely up to you really. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #566225 24th Sep 2016 1:19pm
ericvv
Post #566227 24th Sep 2016 1:27pm
My
Genuine Wipac Crystals never had any out of the box, it seems some do others don't. ____\We|Will|Win/___
Post #566244 24th Sep 2016 4:34pm
Fifth Horseman
My first set of cheap 'crystal' headlights did not have the bulb shield (or sidelight) and in foggy conditions generated a lot of upward glare. The second set I got were genuine SVX ones with the sidelight holder and bulb shield and generate a lot less glare in fog.
So yes, if the lamps have the bulb shield then use it.
Post #566296 24th Sep 2016 6:56pm
