Home > In Car Electronics > Svx headlights to LEDs
jimsadventure
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Bought a set of led headlights to stick on the svx ,, plug and play but the svx has a separate sidelight connector and the sidelight is within the original light unit , when I connect the LEDs with the new wiring harness to the svx the sidelight connector isn't in use and when I put the sidelights on I'm getting what I think is sidelights and headlights , same as when I switch to headlights , same set up , main beam works fine . Is there a way of just getting the sidelights , headlights to work as they should as I'm sure this won't pass an mot as is ,, help please Thumbs Up
Post #565687 21st Sep 2016 10:25pm
ericvv
Jim, what type LED headlight did you buy? With or without sidelight function?
If with sidelight function, there should be a normal H4 connector for the low/high beam, same as on the standard SVX Wipac cristal headlamp, so plug 'n play, and there should be a separate wire and connector on your new LED headlamp to connect to the sidelight feed, again the same as with the SVX Wipacs.
I once had Speaker EVO headlamps in my SVX, the version with the sidelight function, and that connected as above.
Or did you possibly buy a LED headlight without sidelight function? Which no good for a SVX front.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #565692 21st Sep 2016 10:46pm
JWL
I know this sounds like a long shot but with the SVX being the only Defender with a different headlight/sidelight set up is the loom bespoke or do they use the "normal" loom and instead of plugging it straight to the lights, plug an extension in to adapt to the SVX configuration. In other words if you look back from the headlights following the loom they might be plugged into the "normal" Defender set up, unplug that and use that.
Post #565696 21st Sep 2016 10:49pm
jimsadventure
Thanks for the reply Eric ,, the ones I have only have a H4 connector from the led unit , so are these no good for the svx ??
Post #565697 21st Sep 2016 10:50pm
jimsadventure
JWL ,, I will investigate this in the morning and update with pictures
Post #565700 21st Sep 2016 10:52pm
ericvv
Probably not, if there is no separate wire for the sidelights coming from the rear of the lamp, it must mean that it does not have the sidelight function. The H4 connector has nothing to do with sidelights function, only low/high beam.
Which brand did you buy actually? I believe that Trucklites all have the sidelight function, but with Speaker and Nolden you have versions with and without.
Post #565704 21st Sep 2016 10:56pm
jimsadventure
It was a set I bought at a show , I said to the bloke they were for a svx , he probably didn't have a clue what i was on about , so trucklites will work on our system
Post #565707 21st Sep 2016 11:03pm
ericvv
Trucklites surely should work, as said I believe that those all have the integrated sidelight function, so a H4 connector plus another connector for the sidelights specifically hanging from the back, but check anyway if you decide to buy.
Hope you find a taker with a standard front Defender for that set of LED headlamps without sidelight function you seem to have there now. Thumbs Up
Post #565709 21st Sep 2016 11:19pm
jimsadventure
Been looking Eric and I see what you mean regarding the trucklites with the sidelight function , will get a set ordered up and get these ones sold ,, thanks for your help
JIM Thumbs Up
Post #565711 21st Sep 2016 11:22pm
ericvv
Jim, if you opt for the TruckLites, I think these here below are what you need. TruckLite GEN2 with the integrated sidelight, so with the H4 connector, plus the two other wires, black and white, for the sidelights.
Eric
Here is a English language presentation of a Aussie distributor which confirms they have the park lights function. Could not easily find any English language presentation here in Europe, although I know Nakatanenga do distribute the same.
http://www.narva.com.au/pressreleases/pres...d-headlamp
Now, but this is probably dreaming, how nice would it be if finally these very same TruckLites with the heated lenses would become available for the EU market. Whistle Not sure why, but believe they only come with DOT approval, which is ok for the USA, but not Europe. I think to remember that Brendan on here once explained that the chance of those getting EU approval are very slim.
Post #565718 21st Sep 2016 11:47pm
nakatanenga
Germany
The heated ones are not available in the EU, because they do not pass the E-mark. The tiny wires reduce the light output by approx 25%
Back to your problem: You need units with integrated sidelights as the TruckLite 7" are. Brendan stocks these in GEN2! AFAIK, he is the only one who has them in stock at the moment. WANTED:
SII or SIII in max 1.5k
Post #565739 22nd Sep 2016 8:01am
jimsadventure
Cheers for the above fellas ,, now I need to get hold of Brendan ,, is he on here ???
Post #565863 22nd Sep 2016 8:28pm
leeds
Did someone call? Razz
Jim please have a read here
We have limited stock of the Generation 2 Truck Lites. These are not commonly available in RHD/UK specification.
Generation 1 Truck-Lites typically sell for about £425 in the UK.
Edited to add. Main light has the standard H4 connector. Side/position light requires an extra wiring harness.
Brendan
Post #565877 22nd Sep 2016 8:59pm
jimsadventure
Thanks for the reply Brendan ,, regarding the extra wiring harness for the sidelights on the svx, can I not splice my sidelight wires to the new truck lite wires ??
Post #565885 22nd Sep 2016 9:19pm
leeds
Hi Jim, yes you are correct. I was thinking of the non SVX version when I added the comment about the wiring loom. Apologies about me causing confusion.
Brendan
Post #565996 23rd Sep 2016 9:17am
