![]() | Home > Camping, Caravanning and Holidays > Extra Heat needed |
4ndy Member Since: 04 Jun 2016 Location: Cheshire Posts: 17 ![]() |
If there's plenty of heat in the main caravan, what about a large, slowly rotating (thus quiet) 12v fan to push that heat into the washroom?
Mounted high up it's usually a cheap and easy way to get the warm air along a space. Not an owner... yet! |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I believe that your blown air system uses the brown/fawn pipes with plastic joints. I had a caravan that used the same system a fan forced hot air towards a T piece, one side went to the front of the van and the other towards the back and washroom with the washroom being the coldest part of the caravan, this was due to the washroom being the furthest from the fan.
I was able to purchase a restrictor that was placed in the front line which to force more hot air to the washroom. I don't know if these are still manufactured. Check that the piping has not come off one of the plastic joints. As with any washroom bear in mind electric shock. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
If you look at the back of the Fire there is a divider front to back with a flap gate in that you can adjust try putting more air to the back.
But also where do the pipes run some vans send them outside ![]() ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Are you getting good flow out of the vent? Mike
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
The flow from the vent seems to be ok. just not as warm as the front vents.
I am going to investigate a small fan heater. I have thought of a halogen or IR, but a fan might just be the simplest. |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
We had a similar problem in our old caravan. In the end I fitted a small 240V towel rail. A quick Google will find plenty.
Ours was about £25 from memory. Worked well and just supplied constant warmth to the rear bathroom. You never really noticed it was switched on, but you certainly noticed if it wasn't. Dave Green Goddess - 1998 Defender 110 300tdi |
