![]() | Home > Maintenance & Modifications > Front Runner 110 Water tank |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491
Well i have had a front runner water tank sat in the garage for around 9 months now.
Its been a time issue plus i had been trying to find a way of attaching the 'tap' part so it didnt look too 'pikey' or could be ripped off the cross member - its meant to bolt to the underside of the rear crossmember.
So gave it all some thought and having came to the conclusion the easiest way was to have a disconnect system with the tap on a short piece of pipe, so stowed safely in the vehicle when not needed. Tried a few disconnects before settling on Koolance valves. they claim to only loose 0.2ml on disconnect or something similar!
The Big Outdoors overland activities/gathering event is fast approaching (13-16 Oct) so thought it was about time (last ten years with water jerry cans!) to fit the thing. It was actually one of those jobs that went really well and didnt take too long at all! Tanks fits neatly up in the rear passenger side arch. Click image to enlarge Click image to enlarge Male end of Koolance i have fed in through the rear n/s jacking point, with it routed away from the exhaust. Sleeved the water pipe as well. Click image to enlarge Actual end has a home made cover on it! Click image to enlarge It has two jubilee clips to hold it in place inside the circular mounting working on friction fit! Click image to enlarge The tail and tap Click image to enlarge and all fitted. Click image to enlarge Pipe is pulled out a fraction for connection to be made (push to make) seems to work well so far, with no drips![/url] It took 30L (or just over to fill) Just hoping it still got the same in it tomorrow morning. Really please with a real neat solution utilising space that was otherwise 'spare' Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
That looks great
I'm sticking with jerry cans for the time being so I can walk them to water to fill up. I may change my mind at some point! |
| walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2718
Looks a very neat solution. i was a firm believer in jerry cans but this loks like a great solution. Plus it makes it easier to get at the water.
As above though, How is it filled? Do you have to drill holes in the wheel boxes? That would be the only downside for me 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
i was the same for years, then tried one in Namibia and thought you know what this works when verses the space of leaking jerry can and lifting in out all the time etc etc Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
yep you do - 1 x 52mm hole. would be easy to plate over if you changed your mind about it Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
filler neck inside, so also secure Click image to enlarge as you can see i didnt use a hose to fill it, wanted to measure it in! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Another silly question. I can't remember about the wheel boxes on the 2.4. Are they flat like earlier Defenders or are they stepped like the 2.2?
Knowing my luck the whole would be on the sloped section 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
mine are sloped, from memory all 2.4 and 2.2 with option of seating in back from factory have stepped/sloped seat bases.
hardtops, DCs have single flat surface, Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks for the prompt response. Might add this to the list of future mods then 110 D250 SE HT
| All times are GMT |
