![]() | Home > Td5 > Trailer repeater indicator problem |
| davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888
Does it flash all the time or just once when you start indicating ?
If the latter then that's normal, it's done to prove that the dashboard indicator works (or at least that's the official line...) http://www.yorkshireoffroadclub.net/ |
| drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76
It does exactly what I do with the indicator so if I indicate it flashes for as long as I'm indicating and is off when not indicating
| 300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 828
Mine does this as well. It is to do with the replacement relay for the indicators. The early ones could not control the flashing of the trailer tell tale independantly. I believe that RDX and Wipac now do relays that work as they should once dialled in correctly. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
It could be down to any number of things but I'd start by changing the flasher unit - you may find that there's a none standard one fitted to cope with the LED indicators. The quality of these is "variable" ! http://www.yorkshireoffroadclub.net/
Mine is a wipac one which came with the kit. IF I have any trouble I'll change it but to be honest to date I haven't had an issue. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
I'll take a look at the relay, thanks alot guys
| TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197
this shall cure your problem
http://www.paddockspares.com/adjustable-flasher-relay.html 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
Put in an RDX relay and all now working, thanks for your help
