![]() | Home > V8 > Fuel starvation |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I'm not sure if the Defender is the same set up?
I had an early 2 door Range Rover 3.5 on carbs that had the same symptoms as you describe. It turned out to be the small pick up filter in the tank, which was getting blocked when demanding more fuel on demand. It became apparent when I rigged up a temporary fuel supply to rule out everything else. I removed the old pick up filter, and replaced it with a plastic gauze filter from a spray gun. Never missed a trick after that! Also worth checking if the pump is actualy working at full flow too. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 ![]() ![]() ![]() |
The Defender setup will be pretty much the same, I'll take a look at the pickup filter when I next get the chance. When I went to the garage last time they used a fuel pressure meter and it appear to be at the correct pressure, they couldn't test it under load though. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold ![]() 1985 Land Rover 110 ex mod project Tithonus ~ Sold ![]() |
So to update the situation, I'm not having a problem with fuel pressure. The next thing that draws my attention is the electronics, I have bought a brand new distributor to see if it solves the problem. Will update again once fitted and tested. 1999 Land Rover Defender 110 td5 station wagon
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11082 ![]() ![]() |
Update time:
New distributor fitted yesterday. The problem has now been completely fixed! How nice it is to cruise down the motorway at motorways speeds ![]() 1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold ![]() 1985 Land Rover 110 ex mod project Tithonus ~ Sold ![]() |
Good you sorted it out and now you can enjoy the V8, well jel
