![]() | Home > In Car Electronics > Basic cable guage reccomendations |
There are (from simple to advanced) formulas to calculate the wire diameter needed, but as a rule of thumb one can use 4 Amps per mm2. So if you know how much current your appliances use, add them up and calculate the diameter needed. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
You may find this useful too, especially for conversion between mm2 and AWG.
http://www.rapidtables.com/calc/wire/awg-to-mm.htm ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
There's a calculator on this page:
http://www.12voltplanet.co.uk/cable-sizing-selection.html With various explanations. Fat cables are generally good ![]() Your biggest issue is likely to be the bank of 4 lights. If they're incandescent then that could be well over 30A between them and you don't want significant voltage drop to incandescent lights because the light output is a function of the square of voltage. LED lights, particularly regulated ones (which most DRLs aren't) are better for two reasons. Firstly the current draw is lower so the voltage drop is lower; secondly even if there is a bit of a drop, providing they're regulated lights they'll just draw a bit more current to make the power the same and the light output will be unaffected. If you can dim the light then it's probably not regulated. Something like the Labcraft Scenelights, decent LED headlights etc. will be constant output until they dramatically drop off a cliff. Most DRLs are dimmable. |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
Thank you for your advice. Unfortunately I have no idea of the amps the Windows would draw, I can't believe that it would be more than 10 amps.
Spots on the other hand, I would need some recommendations on what works well and what they draw. |
A pair of 100w spots would draw approx 16A ____\We|Will|Win/___
