Home > Maintenance & Modifications > Cordless angle grinders
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
My ten quid angle grinder has about given up after ten years. Thought about getting a cordless one for more convenience but concerned about it not being very powerful. Does anyone have any experience or such things? And particular model/voltage recommendations? Thanks...
Post #564464 16th Sep 2016 12:41pm
JOW240725
I have an 18v Makita which works fine... for about 5 minutes then flat battery! So depends what you want it for! James
Instagram @suffolk_rovers
Post #564471 16th Sep 2016 12:55pm
I have a Milwaukee M18 FUEL cordless 4.1/2" angle grinder (as well as a range of corded ones) and it is very good indeed, well up to the job.
A hint if you're cutting rather than grinding with a cordless angle grinder - use the modern ultra thin discs, 1mm or so thick. Since they remove far less material you'll get a much longer run time. Be careful not to exert any lateral force on the disc though, only radial.
Post #564477 16th Sep 2016 1:23pm
I've got this one: https://www.buyaparcel.com/p/bosch-angle-g...nd-l-boxx/
only with 3x 5AH batteries. There are 6AH available now too.
Various combination you can buy as packs and come in stacking cases too, they are excellent. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #564484 16th Sep 2016 1:38pm
Cupboard
The Ryobi one isn't very good, lacks power and munches through batteries.
But then I haven't used any Ryobi tools that have been great Laughing
I've made an adaptor that lets you attach the "cordless" grinder to a tractor battery, it's 14V rather than 18V but actually performs better than it did on batteries. The peak speed is lower but it doesn't slow down so much when you load it up.
Our builder and electrician both use Makita cordless grinders for light work.
Whatever you get it's unlikely to last as long as a mains one - if mains is an option then it's going to perform better and be cheaper.
Post #564546 16th Sep 2016 7:48pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I'm with Blackwolf, the Milwaukee is a good grinder but Makita is better for drilling / screwing
Post #564550 16th Sep 2016 8:25pm
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
I've got the same as custom90steve but with three 4ah batteries, they last really well and it's quite powerful. I cut three six foot corrugated steel sheets down the middle lengthways and the battery was hardly discharged. I guess it depends what you want to do with it and how often!
Post #564552 16th Sep 2016 8:33pm
Morepower
New Zealand
I've got a De-Walt 5ah with 3 batteries... Very good (you can't really notice any difference from a mains unit)... However battery life is ok and no more..
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #564564 16th Sep 2016 10:09pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
We have a makita cordless for convenience and it is actually quite good for stock removal but it's not the best for cutting. We also have a fein corded for serious manly jobs and i can't fault in. Word of advice if you use a grinder on stone type materials get an air line and blow it out afterwards, maintenance and all that. Rhubarb and custard let fly with their secret weapon.
Post #564597 17th Sep 2016 9:19am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Another vote for the miwaukee fuel grinder.
Post #569612 9th Oct 2016 10:30am
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Plus one for the De-Walt Xr range 18v lithium....
Post #569627 9th Oct 2016 1:42pm
Romadog
Battery life depends on job being carried out and type of battery fitted. I run 5 Amp/hr batteries with my Makita kit - they now have a 6 Amp/hr one out.
If I'm doing continuous heavy work then the 240v tool is used
If doing small job and not close to power supply or leads an issue then the battery power is used.
Remember HAVs. Changing battery and charging gives an excuse for a break so that tool can cool and operative can rest, and not be as affected by the vibration.
Post #569634 9th Oct 2016 2:22pm
Bluebay
1989 Defender 110 200 Tdi CSW Cobar Blue
We have Milwaukee at work which gets lots of abuse and is still going strong after 18 months.I'd buy one if I needed one at home without hesitation.
Post #569641 9th Oct 2016 2:57pm
