![]() | Home > Wheels & Tyres > New wheels and tyres for grey 90 |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
They look butch!
muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 395 ![]() ![]() ![]() |
Oooft!
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Hutchinson's? NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
more photos please
Correct Norman D
Grey 90 with Hutchinson beadlockers 255/85/16 BFG M/T also with 2 Cargo bear roof bars fitted ![]() ![]() ![]() Click image to enlarge Closer shot of wheel. In two minds whether to go for matt black wheel nuts or not ![]() Click image to enlarge Brendan |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 857 ![]() ![]() ![]() |
Can you supply matt black wheelnuts? I have ZU alloys which have been resprayed matt black and I think shiny black would be wrong. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
Shame about the weights on the outside of the rim…wheels look good though
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 251 ![]() ![]() |
Are the rims made for alloy wheel nuts ?
Thought you shouldnt mix steel wheels with alloy nuts ? Glen Edit looks like they are when I look again. "Rafiki" 2007 110 STW - Rolling rebuild. |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Paint the weights and nuts black
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
^ 1
why are the weights on the outside? Looks 'tuff' though |
The Hutchinson wheels are alloys and have the correct flat recess for the nuts. Steel wheels have a cone shape to take the cone shaped steel nuts.
Alloy wheels often have weights on both the inside and outside of the rim. The 255/85/16 BFG are a heavy tyre combined with the Hutchinson makes a heavy combination. The grey 90 will be on our stand at Peterborough with a cut away section of a Hutchinson wheel so you can see the construction. Have some paint for the weights. Paint on wheel nuts does not readily take to a wheel wrench. Apparently matt black wheel nuts will be available at end of this month. Brendan |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
This also seems an alternative to weights - but I have no experience of it - maybe some others can help?
https://www.expeditionexchange.com/equal/ |
