Home > Puma (Tdci) > Puma difficult to start |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 440 |
Just a quick bump for this thread as I nearly didn't make it to work this morning. It took three protracted cranking sessions to get the vehicle started.
There was plenty of smoke coming out of the exhaust while the engine was cranking but would not fire. I have drained some fuel off the filter but it seems to be 100% diesel with no water in it, so doesn't look like water in the fuel. Seems strange though that this has happened after the vehicle had been sat (in my shed) for a few weeks. I have a nanocom that I haven't had chance to plug in yet but will plug that in when I get home. Any ideas to consider while I wonder if I'm going to make it home or not?! Cheers Dave |
11th Sep 2016 9:58am |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 |
Could it be an air leak with air getting into the diesel line?
Never had this with my Puma but have with other Landrovers. This might explain the need for cranking. |
12th Sep 2016 6:06pm |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
Have you read any codes? I'd be checking the heater / glow plugs and associated circuit.
The plugs continue to heat after the engine has started and without them they do run a tad lumpty for a while. |
12th Sep 2016 6:12pm |
Mine smokes a wee while but always starts, but ditto on above advice >> first target for checking are the glow plugs. Solved the bowel problem, working on the consonants...
12th Sep 2016 10:59pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 688 |
Weak battery?
13th Sep 2016 4:58am |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 338 |
I would bet the problem can be limited to (one of) the injectors or their gaskets. I do not think it has something to do with glow-plugs except your ambient temperatures are extremely low. In that case a faulty CHT-sensor would cause similar problems. |
13th Sep 2016 6:00am |
Problem solved? What turned out? |
2nd Nov 2016 5:54am |
