Home > Technical > How to confirm if half shaft broken?
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
110 TD5. On axel stands with wheels removed.
I'm worried a half shaft may be broken.
With the vehicle running and in first gear and release
Clutch on one front and one rear wheel (left rear / right front) turn.
Same with dif lock engaged.
Is that normal or do I have broken half shaft (or two!)
Is there a conclusive test to confirm one way or the other?
Many thanks
Post #563021 10th Sep 2016 10:16pm
Retroanaconda
It just means you have open differentials in both axles - like every other standard Defender.
You'd know if you had a broken half shaft as you would have no or very limited drive without the centre diff lock in.
Post #563025 10th Sep 2016 10:22pm
srod
Curious to know how/why you ended up doing this particular test?
Post #563028 10th Sep 2016 10:30pm
LR90XS2011
car not running diff lock in and hand brake on , jack 1 wheel at a time, you should not be able to turn the jacked wheel , if 1 will turn something is wrong half shaft, drive flange or diff. DEFENDER 90 TDCI XS,
Post #563067 11th Sep 2016 6:35am
danridge
Thanks guys. I have to change the axle oil so it worth taking the shafts out for a visual inspection?
Post #563069 11th Sep 2016 6:42am
danridge
Fitting new shocks so wheels were off anyway. Was checking play in hubs/prop
Post #563078 11th Sep 2016 8:13am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
If you have been driving with a snapped shaft it would not normally drive if the diff lock was off, I have had to recover various wagons with snapped shafts, each one made hurendious grinding noises with a lack of drive. Drivers complaining the wagons FCensored and it won't drive, I jump in and drive it forward, the look of confusion on their faces Rolling with laughter. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #563095 11th Sep 2016 9:53am
No, a waste of time!
As noted above, if you have broken halfshaft you'll have no drive unless you lock the diff.
If you do have no drive and want to check which axle has the broken shaft, get a helper to see which propshaft turns as you try to drive off with diff unlocked and foot hard on the brakes. The propshaft which is turning is the end with the problem.
Post #563109 11th Sep 2016 10:53am
danridge
Ok Thumbs Up Many thanks
Post #563173 11th Sep 2016 6:51pm
