Home > Td5 > Electric Window Problem
DunningBoy
Hi,
Wonder if anyone can help. I've bought a new front passenger electric window regulator but when I came to fit it today I discovered that a previous owner had bodged the wiring. The connector into the electric window motor had been dispensed with and the wiring fed straight into the terminals - the space had then been flooded with resin or similar. Does anyone know if I can buy the connector block to make a proper job of refitting?
Thanks
Duncan
Post #562968 10th Sep 2016 6:37pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
https://www.facebook.com/Land-Rover-Connectors-725872574111124/
I got the connectors from there. The defender has migrated, leaving the owner behind.
Post #566018 23rd Sep 2016 10:36am
DunningBoy
That's perfect thank you very much.
Post #566140 23rd Sep 2016 8:09pm
