![]() | Home > Maintenance & Modifications > Wipac Crystal Halogen headlamps and better bulbs - worth it? |
Basically the same yes. Steve.
I've made up my own loom with relays to go with the Chrystals and 50% brighter bulbs, I had the same bulbs in the original Quadoptics and now especially with the relays they are miles better. Really worth doing
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
![]() Click image to enlarge Stacey I have led sidelights with Quadoptics but with Osram night breaker bulbs. They produce a good result. I am tempted to get crystals. Your original picture looks like your headlamp is misaligned. Compare to mine above. The lens looks too twisted from the vertical. You will get poorer performance on the road like that. 1995 Defender 110 CSW 1971 SIIA Lightweight |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
I see what you mean.
The MOT guy did it as said they were slightly out? |
Should of used adjusting screw not rotated it. I will send you a link to help when I am back on my laptop. 1995 Defender 110 CSW
Excerpt from manual shows adjustment screw and how to set against a wall. 1995 Defender 110 CSW
