Home > Technical > Stiff suspension advice required
Gnasher141
United Kingdom 1986 Defender 90 V8 Petrol HT Sumatra Black
On my 90 V8 with LPG - I think it has a 2" lift on heavy duty springs, or it could just be heavy duty springs giving it a raised look, I don't know - as it was in this form when I bought it.
The ride is very very hard and I would like it to be a wee bit softer to save my back. I think the shocks are at their limit as the wheels do not extend when jacking up.
Any advice on what rate Spring I would need would be very appreciated.
See photo as to what's fitted and how it sits.
Thanks
Post #562476 8th Sep 2016 6:48pm
MartinK
Gnasher
The standard spring rates are here (see page 2 of the thread):
http://www.defender2.net/forum/topic13312.html
However these may be for Puma...
This is another useful link I found:
http://bilashakaflowers.com/LandroverSprings.htm
I've just bought a few things myself - see: http://www.defender2.net/forum/topic49065.html
Hope that helps you... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #562636 9th Sep 2016 8:03am
Gnasher141
Martin
Thank for the reply and links
That's really confused me, I think I may just try standard medium duty springs all round??
Post #562733 9th Sep 2016 4:03pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Suspension..
My vehicle still being under warranty I do not want to fiddle with the OEM suspension.
I did find that dropping the wheel pressures to 1.8 Bar all 4 had a beneficial effect - especially unloaded.
The recommended tyre pressures are only a guideline I think - as tyres do differ in their own inherent sidewall and carcass "hardness/softness".
Found the following link very informative:
https://www.expeditionexchange.com/ome/indexsprings.php
Post #562786 9th Sep 2016 8:09pm
Gnasher141
Hi Sadi
Thank for reply and link
Reading though the link it's saying if I have a winch bumper and winch I need to get heavy duty rated springs at the front, and medium duty on the rears as it has no load except my 45kg dog.
Does this sound right? Surely 2 fat blokes don't weigh more than winch and number.
Mmmmmm
Post #562793 9th Sep 2016 8:29pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
You need four Defender 90 rear springs as h/d fronts are the same as standard 90 rears. Your winch and bumper doesn't weigh more than 2 fat blokes but does sit ahead of the front axle ! 2005 Td5 90 XS
Steve
Post #562800 9th Sep 2016 8:47pm
Gnasher141
If I fit four heavy duty springs won't that make car sit ar$e up? As no load in rear
Post #562805 9th Sep 2016 8:53pm
Lou Sparts
No the standard rear springs as fitted as original equipment are the same rate as the optional h/d fronts. I fitted standard rears to the front of my 300 Tdi when I fitted the winch and it sat nice and level.
There is on here somewhere a list of colour codes for all the different springs used on Defenders and their applications. 2005 Td5 90 XS
Steve
Post #562810 9th Sep 2016 9:00pm
Gnasher141
Post #562816 9th Sep 2016 9:19pm
Lou Sparts
Land Rover used to specify different Spring rates for o/s and n/s but I think they have dropped that now as I have just replaced my rears with off takes from a forum members late 90 and they both had the same colour code. 2005 Td5 90 XS
Steve
Post #562817 9th Sep 2016 9:29pm
Gnasher141
So 2 of them ones?
And 2 of these?
Post #562821 9th Sep 2016 9:43pm
Lou Sparts
That would do the job 👍 Maybe buy some turret retaining rings for the front as the studs have a habit of shearing when you're undoing them (may be ok if you're springs have not been fitted long ago). If buying handed Springs make sure you get them on the correct side when fitting. 2005 Td5 90 XS
Steve
Post #562825 9th Sep 2016 9:57pm
Bps
Do you want to keep it lifted or go back to standard?
D44 and gwyn Lewis are very knowledgable about springs and Spring rates and are worth a call. I rate and use old man emu stuff
I'd try just swopping the rears to start with though. I had heavy duty on my old 90 on the rear and when I soft topped it it was very hard on the rear and I put some medium duty springs, can't remember the rates off hand and it improved the ride no end
Post #562828 9th Sep 2016 10:01pm
Gnasher141
Thanks for advice
I'm going to Peterborough show next weekend, so hopefully there will be some retailers up there.
At least I have a bit more knowledge Very Happy
Thanks
Post #562832 9th Sep 2016 10:10pm
Gnasher141
Does anyone know the identifying colours for the different rate of Spring for Pro Comp?
So I can identify what is fitted to mine.
Thanks
Post #562959 10th Sep 2016 6:57pm
