Home > Maintenance & Modifications > Horny problem
BigWheels
Horny problem
I have 2 Stebel Nautilus horns fitted vertical on RH side of my Puma's engine . The OEs are in their original places.
All 4 never sound at once. Used to be depending where on the horn button I pressed. Now only the OEs sound.
Is there any way I can make all 4 horns sound together, especially for the anti theft alarm?! Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #562582 8th Sep 2016 9:47pm
Use a direct live fused feed from the battery to a 4 pin relay.
Take a live feed trigger tap from the OE horn as the switch.
It'll then do all the work for you.
Think of spotlight wiring only horn instead.
Triggered by the OE horn not main beam.
No switches needed unless you wanted or needed to.
Use cable capable of carrying the current of the horn and fuse it lower than the cables current capacity but higher than the current draw.
It'll then efficiently and safely protect everything from any issues.
You should be able to do this for under £20. Thumbs Up
Post #562594 8th Sep 2016 10:40pm
