![]() | Home > In Car Electronics > Headlight on/off buzzer |
2 GOS Member Since: 03 Aug 2014 Location: Hertfordshire Posts: 66 ![]() ![]() |
Hi Guys,
I want to fit a headlight buzzer and need to identify the easiest to access headlight feed. It occurred to me that the centre dash/console illuminates when the side/headlights are on, and that could be used for the buzzer. Does anyone think this is a bad idea? Also, does anyone know the wire colours for it? As ever, many thanks. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Dashboard illumination is at pretty much every switch and is red with an orange stripe.
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
In case it is of use. http://defender90xs.blogspot.co.uk/2014/03...uzzer.html http://defender90xs.blogspot.co.uk/
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 ![]() ![]() ![]() |
Having had to go back and switch off the lights (as I'm used to auto switching on our family car) twice in the last 2 days this looks perfect.
Can anyone advise where the best place is to pick up the ignition live (white in the blog post). Thanks Keith Keith |
I'm not sure if the Puma differs from the 300 Tdi on this, but an easy place would be on the back of the ciggarette lighter, as there you have a ignition live and an instrument light on (which is on with sidelights on). Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
^^ VeeTee, nice simple answer
![]() It's probably worth changing the socket to a USB one while I have the dash open. Thanks Keith |
Simali Member Since: 25 Jun 2015 Location: Basingstoke Posts: 46 ![]() ![]() ![]() |
I have a two wire buzzer which i bought of Ebay i had it just held in by two fuses in the main box. I opened the box this weekend to do a more permenent fix and managed to pull,out the cables now i dont know where to put them ! My memory says permanant live and switched live but god knows how i got that in the fuse box 2004 110 CSW (Called Yoda)
