![]() | Home > In Car Electronics > What have I Broken! |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
So I need to move the alpine sub to the rear cubby. Clip the connector off, made up an extension, all soldered etc, connected all up and no bass! One thing I noticed when I clipped the connector off I heard a little 'click' like a fuse going from the centre of the dash. Have I blown something in the headunit? The engine was off. All else is working as before but I am stumped. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Did you not disconnect the battery before doing electrical work?
School boy error, NO Andy
Oh forgot to mention, with the fuses if for any reason you cannot physically see they are in-tact or blown continuity check them with a multimeter the amp fuse is usually an AGU or AFS fuse.
Normally you can fairly easily see. If it's the HU usually a standard blade fuse or mini blade. You should have any issues finding a blown fuse. |
You are correct, lost the 12v from the purple brown feed into the amp connector, but where is the fuse, that's the next issue!!
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Could this fuse be stuck right behind the dash?? Andy
Gave up! I just took a new 12v battery feed from my blue sea fuse box. That ok? Andy
Yeah, that's fine so long as the cable and fuse is rated higher current than the Amp.
Amp powers fuse should be nearest the battery at least for a passive set up. On an active amp sometimes on the rear of the unit. But yes, fuse could be behind the dash. A case of tracing the wiring, if it's a lower draw Amp and configured as more plug and play then it could well be different. Either way, so long as cable is rated high enough and fused adequately you'll be fine. ![]() |
Well I could trace no more, had the entire dash out!
All working now with the new feed,what size of fuse would you think for this feed mate? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
What sub / amp are you running? I'm guessing active set up?
I can look it up for you. ![]() |
It's the factory Alpine. Andy
I'd go for 10 gauge cable and a 20A fuse. I prefer ANL fuse holders and fuses over AGU.
More reliable, less problematic. |
