![]() | Home > For Sale & Wanted > [For Sale] Alive 110 Rear Roll Bar Kit SOLD |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
Open to sensible offers
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
How does this differ from a standard roll bar?
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7942 ![]() ![]() ![]() |
Why have you removed it? James
chris d3 Member Since: 06 Apr 2010 Location: sunderland Posts: 378 ![]() ![]() ![]() |
Where in Scotland are you I may be intrested
To Answer everyones questions
Removed due to fitting a full Bowler suspension kit It's larger than a standard rear bar, Which removes some of the roll and helps with steering I'm near Dunfermline.. Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
I'm intrested if you can meet me in Edinburgh thurs/ Friday.
Hi Chris, I'm off to Oulton Park today (work unfortunately)... I'm back Sunday night late... Then away again Tuesday morning to Germany (work again)... Someone will be home though if you want to collect it..Or I could post it Monday....
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
I may be interested.
Putting softer springs on this weekend - wondered if the std ARB would be OK with that of if I would get too much wallowing in corners... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Hi Martin... When I did some of the development for the Alive 110 rear comfort springs I found that you needed the rear bar to reduce the increased roll and it definitely helped with on road response
Regards Tim If anyone wants to call to discuss anything regards the Roll bar then I will be available on 07947523716... JUst heading off to Oulton Park now, So will be off line until tonight It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
Tim - PM on way Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
