Home > Puma (Tdci) > Aftermarket suspension for Puma 2.2
SkyFallSilver
Kuwait
I like the look of the modified suspension with the yellow shock absorbers, I am not looking to lift my truck or lower it what suspension setup would compliment the defender for offroad and on road comfort ? 2016 Defender 90 Adventure Edition
Post #560872 2nd Sep 2016 7:17pm
Old Man Emu suspension is highly regarded and what I have on the 110...also they're yellow!
Post #560890 2nd Sep 2016 8:14pm
SkyFallSilver
Kuwait
Are they applicable to OEM springs ? 2016 Defender 90 Adventure Edition
Post #560893 2nd Sep 2016 8:20pm
West Yorkshire Lofty
Scotland 2015 Defender 90 Puma 2.2 HT Fuji White
You could also look at Bilstein shock absorbers. They are Yellow and come in standard as we as upgraded. It may be worth upgrading your bushes at the same time.
Cheers WYL
 2015 90 Keeper
2005 R300 Keeper
2019 XC40 Shopping Trolley
2008 110 XS Utility (Friday Build) Gone!
Post #560983 3rd Sep 2016 7:04am
You can change the dampers and leave the springs standard.
Post #560984 3rd Sep 2016 7:24am
SkyFallSilver
Kuwait
Cheers WYL
What bushes do you recommend changing, my car has 50,000km / approximately 30k miles. 2016 Defender 90 Adventure Edition
Post #561014 3rd Sep 2016 11:32am
Morning, SupaPro or Polybush, supply kits that replace the worn rubber bushes. They last longer and tighten the suspension up. I changed my OE rubber bushes when I had 165 miles on the clock!
Cheers WYL 2015 90 Keeper
2005 R300 Keeper
Post #561477 5th Sep 2016 6:29am
SkyFallSilver
Kuwait
am I reading it correct, 165 miles and not 165,000 miles ?
If yes I am surprised that its very early for bushes. 2016 Defender 90 Adventure Edition
Post #561753 5th Sep 2016 10:51pm
SkyFallSilver
Kuwait
anyone tried fox shocks with the standard OEM springs? 2016 Defender 90 Adventure Edition
Post #561754 5th Sep 2016 10:51pm
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
Can't fault mine, totally transforms the ride. I've been very pleased with them on and off road, and that's with the standard 130 springs (and helper rear springs) at the rear which are very stiff.
Post #561874 6th Sep 2016 4:10pm
165 Miles
Yes you read correctly 165 miles, I had the bushes done at the same time as other upgrades. It seemed sensible to have them swapped when the shocks, springs, brakes, galvanised turrets and bushes all at the same time. The rubber bushes could have lasted a couple of months or years.
2005 R300 Keeper
Post #561923 6th Sep 2016 6:46pm
SkyFallSilver
Kuwait
I'll go for that then. 2016 Defender 90 Adventure Edition
Post #561982 6th Sep 2016 8:49pm
