![]() | Home > Td5 > Td5 stuttering |
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
Could be sucking water in side vent or down snorkel of you have one?
Check to see if air filter is wet? Could also be a leak in air filter box 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654
I'd check over the electrical connections and wires through the bulkhead and under the drivers seat to see if any are worn or open to the elements. water and electricity don't work together 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
| smurf500 Member Since: 08 May 2015 Location: oxfordshire Posts: 57
cheers pj.you were on the right track with that.the air filter was sodden
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
There is a dump valve at the lowest point of the inlet ducting that should let water drain out this may have become blocked
Click image to enlarge Number nine in the picture above. 2005 Td5 90 XS Steve |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
as a point, also the air filter box has drain hole too
| 4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 1000
Also if you have a Safari style air intake top, turn it around. The "ram" effect is non-existant for a diesel.
Click image to enlarge 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
