![]() | Home > Maintenance & Modifications > Better securing door bolts |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791 ![]() ![]() ![]() |
You can get the anti removal flat head and tri head screws, or if you used nylocs on the inside and a washer/nylon washer stack, I suspect that any turning on the outside bolt would just spin the inside nut, at least for the back door.
Alternatively this sort of thing. http://www.securityfastenersandfixings.co.uk/Info/argus-7.aspx Or shear bolts, but then you're into the realms of having to grind them out later if you ever need to remove! |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1071 ![]() ![]() ![]() |
I've not got round to doing this yet, on my list of jobs.
I've bought some QuikSteel (https://www.amazon.co.uk/gp/product/B005O0366Q/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). Plan is to grind off a couple of the spikes on a Torx bit, fill the centre of the door bolts with QuikSteel, then use the ground Torx bit to shape the metal in the door bolt. In this way, only my special bit should fit the door bolt in the same way as the locking wheel nuts work. Like I said, not tried yet, I'll let you know when I finally get round to it. |
Ranger Member Since: 17 Nov 2011 Location: United Kingdom Posts: 75 ![]() ![]() ![]() |
http://www.vanarack.com/store/land-rover-d...-slamlock/
http://www.ebay.ie/itm/272331501649 The Hamshaw one's are still available, just get in touch with him. |
Defender marto Member Since: 14 Mar 2016 Location: Wirral Posts: 128 ![]() ![]() ![]() |
That hamshaw one look good, anyone here got one of them?.
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
I filled the holes on the front door hinges on mine completely with metal paste, sanded them down and painted them, and fitted shear nuts on the inside. A bit frightening on a brand new van and yes, they will be a pain to remove, but at least they ought to stay put.
I believe thieves only steal doors if you either own a police Land Rover or if you start a new topic with 'So', though, so you should be okay. Oh, hang on a minute.... |
