Home > Wheels & Tyres > Ifor Williams GD85 - how to put LR wheels on? |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Guessing Your GD85 is a single axle ?
2nd Sep 2016 2:42pm |
rockhound42 Member Since: 24 Jun 2015 Location: where Surrey meets Sussex Posts: 38 |
Yep, should have mentioned that.
2nd Sep 2016 2:43pm |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
Personally I'd call into a local Ifor dealer and talk it through with them to make sure everything goes swimmingly. But, in the meantime:-
I believe the 4 stud axles are on 200 x 50 drums which equates to. KS0825 Hub Kit. To change to a 5 stud pattern you'd need to swap these "Hub Kits" (drum, bearing, etc etc) to the KS0826 which is effectively the same drum / hub kit but with 5 holes instead of 4. However, back to my first paragraph, go armed with all the info but check with you local Ifor dealer / service centre first in case there are descrepancies in the years etc. Above all remember - I'm not an expert |
2nd Sep 2016 9:11pm |
Thanks for that Riccarton. Gives me something to look at in a bit more detail before going to the dealers.
5th Sep 2016 10:54am |
Penuwchian Member Since: 17 Jan 2016 Location: Ceredigion Posts: 60 |
I've got a GD85- and would have thought that the LR wheels would be far too big for it? We've had other Ifors running on LR wheels in the past- but they've then 12.50-16 series type wheels I think? Not sure that you'd get the 265-80-16 tyre to fit at all?
As stated above- best bet would be to speak to a dealer- although I guess they may well just tell you it's not practical? |
7th Sep 2016 9:28am |
muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 395 |
6.50 r16 are an option on Gd84 so definitely possible (with bigger mudguards) He who dies with the most toys...wins!
7th Sep 2016 2:35pm |
