Home > Puma (Tdci) > TRACTION CONTROL WARNING LIGHT
zs1sam
South Africa 2011 Defender 110 Puma 2.4 SW Alpine White
I have experienced the following in MY 2011 Puma 2.4 while on a recent trip to the Kalahari:
1. while travelling on a freeway at less than 100kmph the TC warning light came on. I stopped, swtched enging off and then restarted. TC light now off
2. A while later I noticed that when I braked, the headlight warning light came on. On checking I saw that the park lights came on when I braked.
3. Finally, when I switch the headlights on, the TC warning light cames on as well. Only way to get it off is to switch engine off and restart and not to use headlights!
Any idea where the fault lies?
Post #561475 5th Sep 2016 5:26am
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Are you getting any fault codes?
Checked the wheel speed sensors?
Checked all the earth straps?
Sorry, not much help but will narrow things down...
*EDIT*
Also checked you don't have a blown light bulb? Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #561482 5th Sep 2016 6:18am
zs1sam
No error codes; all light bulbs functioning.
Will check earth straps and sensors shortly.
All this occurred on day one of a 3 week trip as I was leaving Cape Town. We completed the the trip without any issues at all (including sand areas and rocky mountain passes).
Post #561484 5th Sep 2016 6:28am
Fifth Horseman
The earth connections on the bulkhead and transfer box are a good place to start, also check the wiring loom for damage at the rear of the engine and where the loom goes over the transfer box (and any other place it can rub).
Post #561485 5th Sep 2016 6:37am
Bushpig
Perhaps it's something to do with the Kalahari ?
3 years ago while in the CKGR, was where my TC light started flashing.
It was the drivers side front sensor that had rattled slightly loose, gave it a quick clean and simply pushed it all back together.
Did get this error code:
ABS-Brake Module
P0571-13 (ACool Unknown Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #561488 5th Sep 2016 6:44am
Naks
yep, sounds like a dodgy earth connection, make sure you check them all --
Post #561516 5th Sep 2016 8:59am
zs1sam
Thanks for all the tips ............. everyone points to earthing ............... tomorrow and the days thereafter, I'll be checking it all and removing half the Kalahari's sand out the vehicle!
Post #561633 5th Sep 2016 4:29pm
dorsetsmith
Whistle
Post #561639 5th Sep 2016 4:45pm
dorsetsmith
main earth from battery to chassis to transfer box
right hand side brad from the chassis to the body work
Post #561642 5th Sep 2016 4:48pm
zs1sam
Problem resolved ................ feedback
I have a plastic / flexible rubber cover over the trailer plug socket at the rear of the vehicle (not sure what the official name is!). As I do not tow anything I never remove this cover. Water ingress casued corrosion which in turn resulted in a short circuit.
Two switches (micro type) had to be replaced (part no.'s LR 032955 and LR 032956). Cost of parts in ZAR 230-00
(about 15 to 17 British pounds).
Needless to say, this "protective condom" has been dumped!
Post #564261 15th Sep 2016 6:41pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Interesting - thanks for sharing.
Post #564387 16th Sep 2016 5:15am
