Home > Technical > A good chassis/crossmember coating?
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
im after a decent paint/arasol spray to paint and protect my rear crossmember and chassis with, it needs to be a smooth finish so it will match the nas step which I'll be purchasing soon, obviously needs to be very hard wearing.
Does anyone have any recommendations? i was thinking maybe POR15?
Thanks,
Christian
Post #561331 4th Sep 2016 7:12pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
What's the current condition of your crossmember? it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #561333 4th Sep 2016 7:15pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I painted my rear crossmember with gloss black smoothright when I re powder coated my NAS step 3 years ago still looks as good as new. 2005 Td5 90 XS
Steve
Post #561336 4th Sep 2016 7:21pm
leeds
The products from Craig at Buzzweld http://buzzweld.com/ gets good reviews.
Have not used it ourselves yet but have some on order to try out on our rear cross members.
Brendan
Post #561342 4th Sep 2016 7:48pm
Devon-Rover
Bilthamber Epoxy mastic, POR 15 or KBS Rustseal would be my choice with something like KBS diamond finish clear as a top coat to keep it UV stable and retain a high sheen for your requirements.
Google it.
Post #561344 4th Sep 2016 7:49pm
CDN38
I have used POR15 quite extensively, and it's a good product, key is proper prep of the metal surface, using their Cleaner/De-greaser and Metal Prep products. You can't just wire brush off rust and dirt and paint it on and expect lasting results..
Ultimately, a catalyzed product (epoxy primer) will outperform anything from a rattle can, or ready to use can for a base coat. It does require very thorough prep, and a proper top coat, more time and cost. I used a PPG product DP90 Epoxy Primer, then trim black finish on top. it's a Landrover thing...
Post #561355 4th Sep 2016 8:16pm
LittleFoot
I absolutely recommend Buzzweld 's range of products. We use them ourselves
Craig is a really helpful chap and absolutely dedicated to getting his brand out there.
I'd suggest "zero-prep" followed by a coat or two of "CIO" chassis in one.
Post #561372 4th Sep 2016 8:38pm
mikeh501
I think for the exterior of the rear crossmember i would just use any off the shelf gloss black finish in aerosol form.
The chassis inc rear crossmember rots from the inside out, so what ever you stick on the external face is just cosmetic. The most important thing is to protect the inside.
Post #561374 4th Sep 2016 8:40pm
Christian1402
Lots of suggestions here, thanks very much.
I'll have a look into buzzweld products. I have a load of dinatrol rust converter which I was going to use first. My crossmember isn't too bad, but is showing signs of age now (2009)
Post #561514 5th Sep 2016 9:55am
adseybear
Canada
A coat of Buzzweld RCP followed by a couple of coats of CIO. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #561521 5th Sep 2016 10:31am
Christian1402
Have now ordered some aerosol's from buzzweld, not cheap but will do the job
Thanks guys
Post #561530 5th Sep 2016 11:27am
toastkid
Let us know how easy it is to apply, how it covers and how it all looks at the end.
Post #561575 5th Sep 2016 2:13pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Buzzweld CIO:
2K Extreme (doesn't photograph very well, and the iPad camera is Censored )
Post #561748 5th Sep 2016 10:28pm
