Home > Maintenance & Modifications > Exhaust
90def
2011 Defender 90 Puma 2.4 HT Epsom Green
Exhaust
How easy is it to fit a decay pipe to a defender 90 2.4 90 looking to put a straight through exhaust system on cheers Phil
Post #561300 4th Sep 2016 4:58pm
I don't think you want a decayed one. Whistle Laughing
On a serious note, quite easy.
I have a Terrafirma centre and the rest OE, it's done well but fit isn't great.
I'd go for cat back at some point instead, probably will at some point when funds allow.
Post #561315 4th Sep 2016 5:32pm
K9F
Easiest and somewhat drastic solution is to take an angle grinder to your original catalytic convertor pipe and remove it in two pieces. If you want it out in one piece remove the front cross member and unbolt the front propshaft. Remove the heat shields and undo the manifold bolts (4 off). Spray them first and leave them for an hour or two. Extraction from underneath can be tricky and as the catalytic convertor is the size of a small emersion heater it is a tight squeeze. I used a trolley jack to slightly lift the engine to get the extra 2-3mm to get it out. With manipulation it will come out.
The 'catalytic police' will be along shortly to tell you to save your money as it is a potential MOT fail. Your vehicle, your choice, it is IMHO still one of the cheapest enhancements you can do for your engine to allow it to breathe by releasing the strangulation hold the catalytic convertor has on it and allows your turbo to spool up quicker.
My 2.4......Straight through centre box and no rear.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #561345 4th Sep 2016 6:51pm
pannawonica
Australia
I must agree and also say don't chop it too remove, use a BFH after removing the four bolts on the cross member and out it pops! I used some anti seize on the bolts and mating surfaces just in case I have too go back! Thumbs Up Very Happy Very Happy
Post #561467 5th Sep 2016 12:55am
