![]() | Home > Wheels & Tyres > 255/85r16 options |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Thanks for sharing those interesting comparative photos.
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
Have you done a suspension 'lift' as well? It's sure looks much higher now!! Maybe a dumb question, but does fitting these taller tyres also mean the driveshaft splines are further out and perhaps you then need longer ones? Or does this only apply when doing a suspension lift? Cheers! YOLO... You Only Live Once... |
The suspension doesn't change at all when you put different tyres on, save for the change in unsprung mass.
The gearing changes slightly because the tyre radius increases. You put a little more strain on everything in the drivetrain because of the increased tyre momentum and radius, but if you're getting more traction and having to work the vehicle less then that's kinder on everything. |
So, is the general and reasonable opinion that a 255/85/16 tyre IS too 'tall' at circa 33 inches to 'replace the OEM 235/85/16 tyres on a standard non lifted suspension Defender? The last thing any of us would want is clearance issues at full articulation with this size tyre given the diameter is about 20m larger?
Is perhaps the 265/75/16 therefore a better 'bigger/wider' tyre, in that it keeps the diameter about the same? Whatever the answer.... the BFG's KO or KM seem great tyres. ![]() I am about to fit larger tyres to my camper trailer and in view of reading this thread, I am now mulling just getting the same 235/85/16 as I have on my OEM 90, rather than either of the larger sizes, 255/85/16 or 265/75/16 as discussed above, with a view to also going 'larger' on the Defender at some point in the future... ![]() ![]() ![]() |
255/85 fitted on my stock 110 quite happily although I never got it seriously cross axled.
![]() Click image to enlarge Leeds seems to use them on their 110s with no lift too, as do other people. I'm not sure if Blackwolf has a lift on his but I'm pretty sure he's running 255s too. I vaguely recall him making a comment about them fitting but not leaving an room for snow chains but that might have been someone else. jst reckons they just catch on full articulation. |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 315 ![]() ![]() ![]() |
My 110 CSW runs 255/85/16s on standard suspension with no issues at all. Sandy |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
I think 255/85 is the sweet spot for defender tyres, as the other options are either too wide, or not tall enough, or both. The best thing is that it cuts through mud like a 235, but retains the diameter and inherent diff lift of the 285 option, but without the increase in width. Diameter wise theres nothing between a 255/85 and a 285/75. Have a play with this tool and see for yourself https://www.4x4tyres.co.uk/catalog/tyresizes Now, as to whether it would fit with your standard suspension..... there are plenty of people running 285/75 on standard suspension, so if that works so does 255/85. My main point is to understand what exactly you will be doing with it. Running even 305's is possible with standard suspension but if you are planning to go heavily off road and get very articulated then it will foul the arches or eyebrows. If were talking fire roads, gentle green lanes and grassy fields then it wont be an issue. 265/75 was the biggest tyre supplied the factory on standard suspension... These will go fully articulated without fouling your arches or eyebrows. 265/75/16 articulated as far as it would go. about 2 feet of tyre/arch clearance on other side! ![]() Click image to enlarge |
Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258 ![]() ![]() ![]() |
I guess to say that a tyre fits means different things to different people.
My 90 goes through full articulation frequently and also a lot of mud of various densities in the winter. I would never consider a tyre that "just fits" or that rubs in full articulation to be a proper fitment. But that's just my opinion, for my uses, and why I lifted my suspension |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1903 ![]() ![]() |
![]() Click image to enlarge Loving that - a lot ![]() |
Yes we do run 255/85/16 BFG M/Ts on most of our vehicles both with and without lift. These tyres do give extra clearance under axle diffs.. In most circumstances have no problems with them catching on full articulation. Now our red 110has 255/85/16fitted with a 2" lift. Now in extremely muddy conditions with full articulation (no rear ARB) the mud on tyres just catch the rear wing tank. Now hopefully (fingers crossed etc) our grey 90 will be fitted with 255/85/16 on road legal beadlockers in time for Peterborough. Brendan |
Thanks for the very informative replies guys!
Looks like they don't supply the 255/85/16 AT here in Oz!!
![]() Only can find the MT in that size! Frustrating as the MT is noiser and honestly BFG, there is not much mud in Western Australia!! ![]() Given lots of bitumen, gravel, rock and sand roads, the AT is a much more versatile tyre out here IMHO... unless of course you live in FNQ and drive the Telegraph Track unto Cape York! YOLO... You Only Live Once... |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
yep BFG only do the KO2 in 265 or 285 so if you want a 255 it will have to be a KM2 (unless you go to a different manufacturer).
I ran 255 KMs and KM2s for over 10 years but have now moved to the KO2 (285s). TBH it's a much nicer tyre on the road and in the snow (not that you'll get much of that out in OZ!) ![]() |
Sorry for the offtopic Camelman, but is that red Unimog yours?
