|  | Home > Maintenance & Modifications > Offset and wheels |
| languedoc Member Since: 13 May 2016 Location: Edinburgh Posts: 283      |
 Ok, i know this has been asked before but i am still slightly bamboozled about the whole thing.
 So what i want to buy are steel modular wheels (as much as i want Bowlers, I am frequently on rocky mountain passes and cant bear damaging them) i dont do motorways very often so its mainly very windy tarmac or mountain tracks. I think 16" wheels will be better for the higher sidewall and potential increase in grip for snow. My question is, i want wide tyres on the 110 on black steel wheels, how do i sort out the offset to be sure they fit within the arch and not foul when doing tight turns in tiny villages and hairpin tracks? | ||
|  2nd Sep 2016 10:30am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | 16" wheels with an 8" rim width and an ET0 zero offset (the wheels sit 33mm further out than standard but are still within the arch) will do you fine. These wheels will take tyres to a width of 305 with no adjustments, rubbing or fouling issues. I have these size wheels on mine with the same offset and the aforementioned 305x70 tyres.
   Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  2nd Sep 2016 10:44am |
| languedoc Member Since: 13 May 2016 Location: Edinburgh Posts: 283      | Great, makes sense. Its the bloody metric and imperial blend of measurement that gets me confused | ||
|  2nd Sep 2016 10:46am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | 1,300 miles between MOTs this year. Thinking again of selling it. It only has 38k miles on it. Custom Vehicle Operations Harley Davidson Pro Street Breakout is beckoning and at £25k with the dollar exchange rate being as it is and with the factory based modifications I want, the Land Rover would have to go. I did give Customsteve first refusal. But it went a bit quiet.
 http://www.harley-davidson.com/en_US/Motor...akout.html    If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  3rd Sep 2016 4:02pm |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347      | Screamin' Eagle indeed       Worth every penny/dime  | ||
|  3rd Sep 2016 4:13pm |
| Posting Rules
