Home > Wheels & Tyres > Fitting ZU alloy onto Mantec style Spare Wheel Carrier
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
My tale of tyre woes is not quite over although I do now have 5 ST Maxx's on 5 ZU rims and they look fantastic.
However, can I fit the spare onto the wheel carrier which has only been used for steel wheels to this point (obviously I need to use alloy type wheel nuts) or should there be something behind it other than the standard wheel nuts to space it out from the back of the truck.
Advice requested as I now desperately want to get them on the car. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #561002 3rd Sep 2016 10:17am
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
I had the same problem switching from Twisted alloys back to boosts. I went with a spacer to push the wheel out a bit. Strong people are harder to kill and generally more useful!
Post #561013 3rd Sep 2016 11:31am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I had the same issue, there should be some large spacer nuts that fit between the back door and the wheel rim, obviously a set of 3, then you can adjust the distance from the back door to stop it rubbing etc depending on the tyre width. They are fairly loose until the wheel is bolted on.
Like these.....
http://www.xplorlandrover.com/DEFENDER-SPA...ER-GENUINE
Post #561019 3rd Sep 2016 11:58am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I use steel wheel nuts on the inside of the wheel and alloy wheel nuts on the outside. I set the inside 8nes so the tyre clears the door and then use lock the alloy one on so it sandwiches the wheel between the two bolts 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #561043 3rd Sep 2016 2:34pm
300TDi CSW Phil
Thanks guys, I have worked out a solution using the outer plate of my "on the door wheel carrier" cut down accordingly to support the back of the alloy wheel against the stop nuts. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #561052 3rd Sep 2016 3:33pm
Litch
I just screwed a normal nut onto each stud and then slid a large washer onto each one for the wheel to press up against. Screw the nuts in or out to adjust the space between the tyre and the door. ONE LIFE, GET IT!
Post #561053 3rd Sep 2016 3:46pm
300TDi CSW Phil
So here it is the backing plate to take the spare wheel
Complete with vinyl covered cable bike lock to secure wheel to the carrier. Handily the bracket bolted around the tube of the wheel carrier so it wont bounce around.
Wheel on and locked up
Now has the spare wheel cover on as well. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #561279 4th Sep 2016 2:56pm
