![]() | Home > Technical > Clutch pedal travel on Td5 |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Bump
Anyone got info on this ![]() Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
CLUTCH PEDAL AND MASTER CYLINDER ADJUSTMENT
1. The correct height for the clutch pedal from the floor of the footwell, without a mat, to the lower edge of the pedal is 140mm (5.5in), dimension 'A'. Adjusting 2. Withdraw the six screws and remove the top plate. 3. Slacken master cylinder push-rod locknuts to provide free movement of the push-rod through the pedal trunnion. 4. Slacken the adjustment screw locknut. 5. To increase the pedal height, turn the adjustment screw anti-clockwise. To reduce turn clockwise. When correct tighten the locknut. 6. To adjust the master cylinder push-rod, check that the push-rod has free-play through the trunnion. 7. Adjust the locknuts until the push-rod has 1,5 mm (0.062 in) free-play between the push-rod and master cylinder. When correct tighten the locknuts. 8. Check that there is 6 mm (0.350 in) free movement of the pedal at the pad. If necessary readjust the push-rod. 9. Refit the top plate. ![]() |
