Home > Td5 > Thinking about fitting a large Intercooler to my TD5
D922MAT
United Kingdom 2004 Defender 110 Td5 XS DCPU Loire Blue
Hi iv been looking at fitting a larger intercooler to my defender td5 . I have a alive stage ono map. Will it be ok to fit a larger intercooler with this map or would i need to have it remap again as it will have more air flowing thought the intercooler.
also has any ono used TD5 inside on here
Thanks
Post #560353 31st Aug 2016 9:33pm
roel
I don't think you need a new remap. The ECU is measuring the Manifold presure and temperature and also the airflow. So it knows how much air is going in. When you fit a larger intercooler the air will be cooler so the ecu knows that there is more air going in so it knows it can inject more fuel.
You can get more power out off the Td5 engine but that is another story.
I use a standard intercooler and according to my Nanocom my inlet temp doesn't get higher then 55 deg C that is 328 Kelvin
If you would be able to cool it down to 30 C which is very optimistic I think. you get 7% more air in your cylinders so you could have 10 HP more. Mr. Green Roel
2003 90 Td5 (2009-now)
Post #560365 31st Aug 2016 9:54pm
Fatboy Slim
Wales
It'll be fine. Whack it on
Post #560380 31st Aug 2016 10:12pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I would have Gary give it a tweak will be smoother and give better torque
Their black intercoolers are superb 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #560392 31st Aug 2016 10:38pm
lightning
Is there any point fitting an uprated intercooler to a standard TD5?
Post #560449 1st Sep 2016 8:50am
K9F
Not unless you tow or use it in hotter ambient temperatures other than the UK. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #560452 1st Sep 2016 9:03am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
If you fit a larger intercooler, you will need a larger turbo to see the effects at lower rpm.
There's a slight drop in the performance at about 1100 rpm, as you are trying to fill a larger space with air.
If you are not intending on changing the turbo, you can shorten the waste gate rod.
I've done each of the mod piece by piece so that i know the change effects.
stock map
change to 1.222 t-box
write a map
Turbo waste gate shorten
remap again
change intercooler
remap again
changed turbo to vnt
remap again
i didn't push the engine as it's aging and i'm not for milking all the power gains, i'm after an easy drive and better acceleration. it happened over 5 to 7 yrs as much as my pockets could afford. The defender has migrated, leaving the owner behind.
Post #566024 23rd Sep 2016 11:44am
