Home > Technical > Defender let me down for the first time yesterday.
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
After plenty of trouble free miles I had my first breakdown yesterday.
Just coming back from having the chassis treated by Chris and on the M23 in heavy rain.
All of a sudden the wipers started to go slowly and the the battery light came on closely followed by a loss of power.
Managed to pull over on to the hard shoulder ok but with a lot of smoke from under the bonnet.
I thought at one point she was going to go up in flames but luckily it was ok.
I'm in the AA so after a 2 hour wait for a recovery truck I managed to get home.
My first thoughts were alternator from the symptoms but on closer inspection it looks like it is a dead short in the starter motor or one of the cables.
I'll have a better look later today, at least she is back home safe.
 Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #557623 21st Aug 2016 9:33am
williamthedog
Hopefully it will be a simple fix Thumbs Up
Post #557625 21st Aug 2016 9:46am
mse
I assume your earth cables are all ok... Mike
Post #557641 21st Aug 2016 11:12am
miker
Friend of mine had a similar issue on a 300tdi. Was the sense line that comes off the alternator output, shorted to the engine block. Check your wiring!
Post #557650 21st Aug 2016 11:39am
Cupboard
Dead short *in* the starter?
Even if there was an issue with the starter why would that appears whilst driving along unless it was an issue with the solenoid?
If you measure the resistance of the starter it will always read as if it's a short because it's such low resistance.
Post #557829 21st Aug 2016 9:14pm
Baz8046
Thanks for all the advice.
I've not had chance to have a look this weekend but hopefully I'll get time during the week.
I'll definitely check the wiring first and see what I can find. Defender Td5 Commercial 2002
Post #557889 21st Aug 2016 11:17pm
Baz8046
Just a quick update on this.
After checking the cables which all seemed ok I dropped the starter off this evening.
The top bolt isn't the easiest to get out but with a bit of perseverance it came out from underneath with the right length extension bar.
The starter is burnt out and very crispy inside, I think I was lucky it didn't catch fire.
New one on order from Steve at AF so should all be sorted by next weekend.
Post #559850 29th Aug 2016 10:55pm
Cupboard
why would that cause a problem whilst you were driving though? I'm still thinking that might be a symptom of another, related problem rather than the cause. Key getting stuck in the start position or starter solenoid getting stuck or something.
Post #559888 30th Aug 2016 8:32am
shaggydog
Shocked
Scary stuff, glad you escaped in time! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #559952 30th Aug 2016 12:42pm
Baz8046
Thanks, there was a few minutes whilst she was smoking I was really nervous.
Good point cupboard it could still be a wiring issue.
I think the normal mode of failure is for the solenoid to stick on causing the starter to stay engaged and overheat.
On mine it had caused the starter to short bringing the battery down and causing the electrical issues.
My ignition switch is fairly new but I will check the circuit before fitting the new starter. Defender Td5 Commercial 2002
Post #560073 30th Aug 2016 8:55pm
dorsetsmith
Post #560080 30th Aug 2016 9:03pm
Cupboard
If the starter overheats and seizes then up until it catches fire it will appear as (or at least so close to that you couldn't tell) a short Thumbs Up
Post #560213 31st Aug 2016 1:16pm
Baz8046
Thanks for the info and the wiring diagram which is very useful.
I think I'll replace the relay as well to be safe as I would hate to fit a new starter and have the same issue.
The ignition switch was replaced with an original one when I put a new lock set on six months ago but I will check it is working correctly. Defender Td5 Commercial 2002
Post #560253 31st Aug 2016 3:02pm
