Home > Technical > swivel hubs
srod
swivel hubs
Recently noticed oil around the swivel on the passenger side, not sure how long it's been like this. Not dripping or owt, just not dry like the other side.
Is this a problem, Do I need to do anything about this soon?
Right, driver's side, totally dry:
Left, passenger side, slightly oily:
Cheers!
Post #559852 29th Aug 2016 10:59pm
miker
Drivers Side is so dry I'd be worried that there's not grease in it!!!
Post #559854 29th Aug 2016 11:31pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
For the sake of a mornings work and a few quid I would strip both sides down, new seals and a new one shot of grease in each. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #559856 29th Aug 2016 11:41pm
williamthedog
As miker said
It seems too dry the other side.
They all weep slightly.Think you should sort it sooner than later Neutral
Post #559874 30th Aug 2016 7:28am
Mo Murphy
Personally, I don't think there's anything wrong with it. Most have a swivel that seeps a little bit. If it bothers you, clean it up and do it again next year.
50 Shades of Pennine Grey
Post #559896 30th Aug 2016 8:46am
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Mine are the same but the other way round, drivers side is damp, passenger side dry as..
I think as long as it's not pouring out just leave well alone. A quick wipe at MOT time Thumbs Up
Post #559931 30th Aug 2016 11:18am
srod
So a range of opinions Smile thanks to all for the advice.
Regarding the dry side - as I understand it the grease in the swivels on an '03 TD5 can't be topped up, but will require stripping cleaning out the old and topping up with the correct amount of new grease...
If a complete strip and rebuild is needed, then given the time involved maybe it's better to leave it until the swivel itself or something else in that region (bearings? brake discs?) needs replacing and do it all in a oner? Seems like more than a mornings work (for a first time attempt), although happy to be convinced otherwise!
Post #559987 30th Aug 2016 3:49pm
Mash
The tracta seals are easy to do;
Wheel off
Disconect steering arm
Remove brake calliper and hang out of way (removing top bracket from hub)
Remove bolts holding hub assy to axle casing
Slide it off including drive shaft
Flip on front
Remove retaining bolts on plate
Remove seal
Repeat process backwards to reinstall (new calliper bolts to be fitted) 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #559994 30th Aug 2016 4:18pm
