![]() | Home > For Sale & Wanted > Binned Sound Deadening Disks |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Sound deadening disks
2mm-ish thick by 275mm-ish (don't have one to hand admittedly ![]() Double sided so one side sticks to the panel, the other to the carpet or different layer or just leave the top layer on. I have used these in my roof with self adhesive foam over the top and it made a difference. I couldn't directly compare to things like Dynamat or skins but has made a difference to my 200Tdi. The manufacturer Antiphon claim "The weight of antiphon® LDTM material is half the weight of common bitumen pads with the same sound reducing properties." This may be tosh but as I say I haven't compared directly. I have approximately 30 disks available, 50p a disk sound ok? Postage between £3 -£20 depending on how many you need. ![]() Click image to enlarge ![]() Click image to enlarge Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Binned
![]() Self confessed mileage hunter ![]() |
