![]() | Home > Technical > Steering stiff on RH turn after steering box change. |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 251 ![]() ![]() |
I spent the day troubleshooting and its in the steering box, not sure if its an adjustment.
Sounds like its a job for an indie. "Rafiki" 2007 110 STW - Rolling rebuild. |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Have you checked that the clamp on the steering column shaft down to the box isn't catching on the turbo to intercooler hose? I had the same problem with not being able to turn right because of this.
Cheers, |
