![]() | Home > Maintenance & Modifications > MY08 nut and bolt restoration - your thoughts? |
| mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142
Im in the process of doing a rebuild on my 1994 90. I think this is year 2 now lol. Mine is however been rebuilt to a different spec than the original which is bringing some new challenges! A few thoughts since starting my own...
* you will need quite a bit space to put panels and parts of the vehicle. * Your going to need lots of tools, and a decent engine hoist for the heavy bits. * you will need a good friend who can help with some of the heavy or large bits. * decide whether your going to strip to a bare chassis, this is a big job, and the costs will rocket. Simply because there is more opportunity for "whilst X is off, id better replace it with a new one (or an upgraded one)". * Id say the bulk of the work is in the chassis, suspension, axles, engine & transmission and bulkhead dressing/wiring. The body is much quicker/easier. * Factor in lots of time spent cleaning, prepping, painting various bits of bracketery etc. Takes an age. Also an opportunity to galv various bits which are plain steel originally. * Get friendly with a land rover parts outlet. Guess that will be even more important given your location? I needed parts all the time, and plenty of times id forgotten a bit and needed to get something id missed. This should be easier on a puma, but has been a nightmare on my build given its non standard. * Ive not go to paint on mine, but to do the job properly - especially with a colour change; it will be expensive. In addition, most painters hate waxoyl type products so the bits will need to be properly clean. * Get a whole load of stainless steel bolts, washers and nylocs before you start in various lengths and sizes. You need A4-70 for anything not load bearing. Either go A4-80 for load bearing or just go for the proper LR bolt. I used the original LR parts for some of the safety critical stuff (some suspension, calipers, stub axles etc) oh and last bit.... it will be off the road for longer than you think. dont rush it, just because you need it on the road. The rebuild experience itself is part of the fun. Enjoy... anyone can do it. |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
These guys documented the rebuild of a 90 in a series of YouTube videos , worth a watch to see how they did it.
http://funrover.com/featured/land-rover-defender-tribute-build/ Plus if you haven't see " A 4x4 is Born" by Mark Evans, have a look. A YouTube copy is here (well most of it) &list=PLIiqQSKmq49FkZhI4PRfajOFV3wDHkWee cheers simon |
