![]() | Home > Maintenance & Modifications > Excessive Corrosion or OK? |
FizzBuzz Member Since: 27 Aug 2016 Location: York Posts: 2 ![]() ![]() |
Looking at buying this 04 plate 90, this would be my first defender and unfortunately I don't know anyone to take to a along to get an opinion from so I've been to have a look taken some snaps hopefully you can advise me better.
Doors and bulkhead look really clean. In a moment of utter stupidity I forgot to take any of the engine bay which wasnt the smartest. this is chap in question Thoughts, if nothing looks to bad planing on looking at it again/ taking a test drive on monday, anything in particular i should look out for? Cheers. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
I would run a wanted add on here seen some really good ones come up for 10k DEFENDER 90 TDCI XS,
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
It seems a great deal of money to me, despite the bolt-ons. No mention of any service history either.
If only for reference purposes I would look at several more just so you have something to compare against. When you look at them makes some notes. Lift the floor mats and check where the steel bulkhead meets the floor plates. Look at the windscreen hinge areas on the bulkhead in the top corners. Look carefully at the rear cross member too. Make an estimate of how much of the chassis still has paint on it. 90 Hard tops are relatively plentiful too so there should be lots around, and most importantly, don't be swayed by the bling. |
Thanks chaps, going to have look at some others.
Anyway to tell what sort of state an engine beyond it starts first time from cold and pulls ok though all gears? |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Looks like it has not been cherished and used as a working truck (which is what they were intended for) but if it has had a hard life then take this into some of your deliberations. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
