Home > In Car Electronics > High Level LED brake light
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I got fed up waiting for a high level brake light LED panel that I decided to make my own..
The PCB's should arrive in a week, LED's already here.. Just a quick dremel, and 3D print a couple of brackets, and Bob's yer aunties live in lover for about £12
I'll post some pix when the bits turn up.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #559257 27th Aug 2016 12:07am
barking
Australia
Looks great. Where did you source the pcb from Shax? I am in need of a slim line light as the cage I have in the back of the car hits the original.
Post #560220 31st Aug 2016 1:28pm
Shax
I designed the PCB file myself in Sprint Layout6.. Just waiting for the boards to arrive from China..
The LED's and other bits are waiting to be soldered, Dremelled and bolted!!
Pics to follow as promised, once I've assembled it... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #560310 31st Aug 2016 8:02pm
Cupboard
I get my PCBs from Seeed Studio: https://www.seeedstudio.com/fusion_pcb.html
Their pricing is good, their service is good, the quality of the stuff that arrives is good.
I've had stuff done in the UK by PCB Train and would only use them if I needed it within a few days. Otherwise if you go for the fast turn around you can get stuff from Seeed within a week-ten days and it's a whole lot cheaper than PCB Train.
I used to use Easy PC to design them but now use RS Designspark which is the same but with different branding and it's free. If you then want to make a box for them you can export the PCB design in to the 3D cad package very easily too.
Post #560332 31st Aug 2016 8:44pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Shax, if you are thinking of selling these, I would be interested, the high level break light is the only non LED light on my truck. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #560342 31st Aug 2016 9:08pm
Don't mean to rain on anyone's parade but what about 'e' marking?
Currently it still applies. Rolling Eyes
I know how annoying it is having all lights LED except one, used to be side repeaters on mine until they were produced.
Post #560344 31st Aug 2016 9:26pm
ericvv
And that is unlikely to change in the future for you. Laughing
Nothing to do with being in or out of EU. We also are not in EU, never were actually, but E marking is a must in Switzerland. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #560346 31st Aug 2016 9:27pm
It's not a bad thing but due to cost puts manufacturers off producing these items.
So in the end we go without unless it can be proven there is a definite demand.
Post #560352 31st Aug 2016 9:32pm
Shax
E marking...?? Hmmm... Now that's an interesting question..
So I currently have an E marked high level brake light, using a 21watt bulb, and it's been E marked with that 21watt bulb.. Now, I wander off to my local LED bulb reseller, and buy a 5watt LED cob light to replace said 21watt incandescent filament bulb.. The original E marking test is null and void...
But no one bats an eyelid, because I am doing the "green" thing by using less watts of leccy!
ALL the LED bulbs I have seen have no E mark on them.. The E mark is moulded on the red lens on the assembly I'll be butchering.. And lets face it, EVERYTHING is supposed to be CE marked too, which I now take to mean China Export!!
I've also read on one of these very forum pages that the high level brake light is classed as an accessory, and not subject to E marking anyway!
I'll not be reselling high level brake light led panels, but if people ask nicely I may sell them a bag of bits to build their own red high output panel, for use as a device to preserve ones ability to see in the dark, without losing ones Scotopia (noun: the ability of the eye to adjust for night vision - Collins)
Oh, and they also come in white and UV... If I could source enough 905nm IR leds, it could also be used as a lidar jammer, but the Defender don't usually go fast enough to worry about that!!! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #560366 31st Aug 2016 9:55pm
nakatanenga
Germany
Hi,
E-marked 3rd brake light is ready! 3 colours available. pictures coming later the day
Peter WANTED:
SII or SIII in max 1.5k
Post #560435 1st Sep 2016 7:38am
Cupboard
According to K9F on a different thread:
K9F wrote:
ericvv wrote:
Thought to ask you specifically, you are after all the guru of the E-marking and IP rating (latter not appliable in this case). Thumbs Up Thanks, Eric
A point to note here is that a third brake light is not an 'obligatory light' and does not have to be e-marked, so effectively you are getting an added bonus.
Rolling with laughter Bow down
Post #560495 1st Sep 2016 1:02pm
Shax
The PCB's for the HLLBL turned up today... Just don't have the time today to solder one up!
But as promised, I'll drip feed the fotos as I take em!
The panel uses 90 x 3mm ultrabright red LEDs, and are arranged in two banks of 45.. There is a reason for this, but that's hush hush for the time being! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #561667 5th Sep 2016 7:25pm
dgardel
Italy
nakatanenga wrote:
Hi,
Peter
I WANT ONE!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #561828 6th Sep 2016 12:39pm
Shax
High Level LED brake light - Continued!!
Hi All!!
Well, I finally soldered a panel up, and it looks pretty good...
Just need to fit it into the current housing... But in the meantime, here are a couple more pix of the panel..
Fully populated panel
Lights on!!
I'll bung a couple more images up when I get round to fitting it in the rear window.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #563422 12th Sep 2016 7:10pm
Cupboard
Are you going to have them alternate flashing then?
Post #563573 13th Sep 2016 10:04am
