Home > Puma (Tdci) > Turbo heat shield .. is it necessary? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Been running mine for a couple of years without it, and de cat.
No problems at all. If anything it probably keeps it all a bit cooler. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
25th Aug 2016 10:14am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16934 |
Mine is in situ to help conceal the absence of cat, however everthing is cooler without the cat and I don't think that there would be a problem running without it.
If you do remove it though, bear in mind that the absence of the irritating rattle it makes will allow you to hear many other worrying noises that you cannot presently hear! |
25th Aug 2016 12:47pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 695 |
Great .. thanks for the replies. It's coming off.
I've got a leaking manifold to turbo gasket again so it all needs to come apart tomorrow anyway .. one less thing to put back on! 2008 Defender 110 XS SW - M57N2 / 6HP28X |
25th Aug 2016 12:50pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3700 |
What does this part look like as I had a rattle and a small heat shield was loose,
Sort half a coke can size? I've since left it off and its done some big journeys.. and been fine. in fact this is it. Do I need to re fit it? from the crank shaft after a google. I've seen no difference in temperature since off. Click image to enlarge |
25th Aug 2016 2:08pm |
Crank sensor heat shield.
Again, like you say the cause of a very annoying rattle as the rivet holding it together wears away! Many don't ever get refitted 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
25th Aug 2016 2:42pm |
My CPS heatshield was missing when I bought my Defender six years ago, and now, nearly 200,000 miles later, it is still missing and I am not aware of any ill effects.
It is also a very awkward thing to refit since it is almost completely inaccessible, no doubt this is the reason most don't get replaced. |
25th Aug 2016 4:12pm |
The tin foil is ripped on my one of them so it's dangling off.
The bracket on the turbo heat shield has a crack down one end that rattles annoyingly at certain RPM. I keep meaning to fix it but then forget. |
25th Aug 2016 4:51pm |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 725 |
Hello all
I have a funny noise in my engine when accelarating would this be the heat shield...what are the symptons for a loose heat shield so.i know if it is that or not And is it expensive to fix might be the turbo one but i dont know without advice from the best defender owners which are on here Thanks muchly Arran |
13th Nov 2017 10:09pm |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 |
"I have a funny noise in my engine when accelerating would this be the heat shield or the wife so very hard to tell ,teeth or bearings
13th Nov 2017 10:24pm |
Jakkals Member Since: 08 Aug 2017 Location: East London Posts: 5 |
The bracket holding my heat shield has broken. was wondering if it was worth replacing. It has a bit of a rattle, but nothing severe. unless there's another function that it preforms, I'm happy to leave it as is.
17th Nov 2017 10:35am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Turbo shields have a few purposes, a turbo blanket is on my list of to do's: https://www.ptpturboblankets.com/pages/why-use-a-turbo-blanket
A turbo blanket protects components within your engine bay. The turbo blanket isolates the heat produced by your turbocharger, and prevents that heat from damaging, or even igniting, components surrounding the turbocharger within your engine compartment, such as plastic and rubber hoses and electrical wiring, as well as painted surfaces, such as the engine bay and the surface of the hood. Also, it prevents areas of localized high temperature from damaging the engine itself. For example, a common cause of head gasket failure in turbocharged vehicles is localized heating of a portion of the engine. The heat differential between the portion of the engine near the turbocharger and the rest of the engine can cause warping of the head, and thus, head gasket failure. This has been a known cause of head gasket failure in both OEM and aftermarket turbocharged vehicles. A turbo blanket improves the performance of your turbocharger by keeping "the hot side hot". In keeping the exhaust gases within the turbocharger hot, turbocharger efficiency is improved. As you may know, the hotter a gas is, the more expansive it is. Within a contained system of a specified size, the more expansive a gas is, the greater the pressure derived and thus, the greater the flow of gas to escape the containment. With this increased pressure and flow rate for a given engine RPM, the acceleration of the turbocharger's impeller is increased as compared to the same turbocharger with the engine at the same RPM but with cooler exhaust gases. This equates to faster spool up of the turbocharger, as well as greater attainable levels of boost. What a driver will experience with a turbo blanket is greater turbocharger responsiveness. The faster spool up of the turbocharger means less turbo lag and a more linear power curve. A turbo blanket improves the performance of your turbocharger by keeping "the cool side cool." As you may know, it is very important to keep engine intake air cool. This is why intercoolers are often utilized with turbochargers. Similar to above, the cooler a gas is (such as intake air), the more dense it is. The more dense the intake air, the more oxygen it contains per unit volume. The more oxygen reaches the engine, the more power can be obtained. In keeping the heat of the exhaust gases contained within the hot side of the turbocharger and away from the cool side of the turbocharger and the intake path, more oxygen per unit volume reaches the engine, and thus, more power. 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
17th Nov 2017 10:47am |
No other function, if you can live with the rattle you can leave it be, although it is possible that with one end unsupported the other will fail in due course. It is a very sloppy piece of design by Ford. On my '07 the bulkhead end fastening has failed since the thread in the manifold has eroded and I have been running for years with that end rattling with no ill-effect (other than having to turn up the radio). I don't fancy fitting a new manifold simply because of this, although I might try 'timeserting' it one day (I am not sure if there's enough depth in the drilled boss for this, and it is a blind hole). |
17th Nov 2017 12:50pm |
Did you just swap it out with an original part or are there any upgrade gaskets out there? |
27th Dec 2017 2:34pm |
MartnH Member Since: 30 Oct 2017 Location: Nsw Posts: 28 |
I think heat shield works
and I also added a turbo blanket |
29th Dec 2017 1:26am |
