![]() | Home > My Defender > TD5 alternator change |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292 ![]() ![]() |
Found a manual that suggests having to remove everything round gear lever to expose top of gearbox. Seems to be implied that there's a plug/socket I can disconnect just to check its not the switch. Anyone know whether I can get at it from below? Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
Fault identified !! It was the reversing light switch that was blowing the fuse you mentioned. Just for reference lying under the 110 with head pointing up to front of car, on the RHS yiu can just see a plug and socket with two wires coming out of it and disappearing somewhere upwards. Those wires go to the reversing light switch. Unplugging the connector and the fuse doesn't blow, the brake lights work, the battery symbol on the dashboard is there and goes out when you start the car and the battery has ~14.5 volts across it And yes you do have to remove transmission tunnel to change the switch, can;t even see it from down below! Result! A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Bonus. Should save you an alternator! Dont look up the price of a genuine one from a LR dealer....
![]() Regards John M0VAZ Econet Station 48 no clock |
