![]() | Home > eBay & Bargain Spots > Maxxraxx 4 bike rack - spare wheel on the rear door version |
| Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692
So far is £40.50 with no bids and they cost a lot more than this
http://www.ebay.co.uk/itm/maxxraxx-4-/1220...Sw9NdXuBEz |
Doh - hope the one I bought on fleabay earlier this week is the right one as the seller said it was
Also bought a 50mm spacer so should have the reach needed but we will see what the outcome is. |
| pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
They are really good racks - that is a bargain, generally towball mounted ones provide much safer bike transport
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274
I hope it works Steve as I think they are one of the best towball mounted racks for the Defender with the rear door mounted spare. If you go on their website you'll see what I mean regarding the offset. The version they recommend for the Defender has quite a crank in the tube as you'd imagine. Much greater offset than some of the other generic 4x4 offerings. I would imagine that if you've got the right version then you won't need the spacer. Either way, I'm sure you'll engineer something if you need to. |
