Home > Maintenance & Modifications > Fuel filler wobbly
Sarah99
Fuel filler wobbly
My TD5 fuel filler pipe is loose and wobbly, it looks like there should maybe be a rubber gasket around the neck bit between the panel and the pipework but I'm having trouble tracking down info for this part, if it exists?
Was thinking about using some sort of putty to make a seal/fix around the pipe to hold everything but there is probably a correct was to fix this!
Grateful for any advice, thanks.
Post #558522 24th Aug 2016 9:01am
Fifth Horseman
Grommet - part no. WLR000020 is what you need (should be less than £5)
Post #558685 24th Aug 2016 8:51pm
Sarah99
That's brilliant, thanks!
Post #558759 25th Aug 2016 6:28am
