Home > Technical > Speedo lights
Scott_Landy
United Kingdom 1993 Defender 110 200 Tdi CSW Firenze Red
Speedo lights
Just in the process of fitting a Raptor new instrument panel and looking to solve the poor speedo light. Discovered that one of the green lenses was broken. Any ideas or how to get into the speedo to get the broken ones out and what to replace them with? Thinking of upgrading to LED bulbs whilst I have access but ideally don't want them to be green. Photo with the hole where the holder should be.
Post #557725 21st Aug 2016 6:19pm
Scott_Landy
It's on a '93 200 Tdi if that helps at all...
Post #557919 22nd Aug 2016 7:44am
spudfan
Ireland
From the handbook
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #558335 23rd Aug 2016 5:11pm
Scott_Landy
Thanks spud. Bulb swap is done ok now.
Guess hand books don't cover "we used chap plastic parts so when the white bulb holder snaps off and leaves the green lends inside the speedo, well, you're on your own with the rattling from here to eternity...."
Post #558339 23rd Aug 2016 5:33pm
spudfan
Ireland
If you undo the speedo cable and withdraw the bulbs and connections then withdraw the instrument panel you can hold it upside down and give it a shake. Any luck the offending bits will fall out! 1982 88" 2.25 diesel
Post #558389 23rd Aug 2016 8:32pm
Scott_Landy
Super,glue! Hopefully that will solve the problem! Guess I stick with Greek lights but from an updated LED bulb.
Thanks Spud!
Post #558432 23rd Aug 2016 10:23pm
spudfan
Ireland
Thumbs Up 1982 88" 2.25 diesel
Post #558443 23rd Aug 2016 10:36pm
