![]() | Home > Technical > Creaking by pedal box 2013 puma 90 |
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2274
I told you exactly wot it is . 100% mate . Gota replace a silly wee bolt wi a bigger one at the exact point you are talking about .. Get em to rock it side to side HARD whilst the monkey lies underneath and goes " ah ! There's the
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674
Id be interested to know which bolt as well, as mine is still creaking!! DEFENDER 90 TDCI XS,
| RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633
Mines too, but just got very used to it, don't really notice it now.
| Samblers Member Since: 29 Jan 2014 Location: Perth, innit Posts: 63
Guys, see my comprehensive post (with pictures) on how i solved my year-long battle with the creaking/notchy puma clutch pedal
http://www.aulro.com/afvb/90-110-130-defen...ost2313715 Cheers, Sam |
thanks Shamblers
unfortunately mine isn't clutch related it does it during steering and suspension movement or when braking / accelerating and can be felt through the floor, I think its body/chassis fixing related rather than steering or suspension and tightening a load off loose bolts in the floor area has reduced it, my Mrs recons that from the passenger seat the noise is behind the dash but from the drivers seat it feels like its in the floor. I did have the clutch spring squeak issue but some spray grease sorted that. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
| MVS Member Since: 20 Sep 2014 Location: N Yorks Posts: 16
Here's pictures of the culprit on mine;
Under carpet below hand brake
Side on underneath. Actually loose & captive washer pulling through chassis bracket
Directly from below
Replaced with bigger bolt/washer/Nylock ![]() |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346
so what exactly is being bolted to the chassis with that bolt cos my initial interpretation was that the floor plate was bolted to the chassis but it clearly isn't. the floor plate is cut around the bolt?
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762
The seat box.
| MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 264
Mine was the coils in the clutch pedal spring rubbing together. A dash of 75w90 fully synthetic gear oil and quiet as a mouse for nearly two years. (Gear oil because it does not dry out) 1953 80"
1987 mini city e 2011 90" |
This is going to sound like i'd moan even if I won the lottery.....but....
I've had issues since day one, some have come and gone but the clutch related problems have never completely gone away. Something (clutch pedal, transmission mount, clutch?) felt like it broke, moved into alignment and now no problem changing ie it doesn't feel like the clutch is dragging when changing as you can blip th engine revs, vibrations in gearbox are gone? I should and am happy but what the hell is it as I have a feeling it ain't going to last? |
| Curtis-Bay Member Since: 10 Apr 2016 Location: Blockley Posts: 29
I have had exactly the same symptoms for a couple of months and diagnosis was virtually impossible because the problem only began after about 30 miles - probably when the floor area around the handbrake began to get warm. I tried pedal lubrication, seat runners, handbrake and floor panels but to no avail.
I lifted the floor mats and located the bolt mentioned by Keith and it was loose. I tightened it up and the corresponding one on the passenger side and BINGO! - no more creak. You are a genius. |
| justinp Member Since: 24 Jun 2016 Location: Cambridge Posts: 167
My clutch is feeling a little creaky / rough at the top of the travel, I checked the bolt beneath the handbrake, and sure enough it was very loose, so I've tightened it up.
Sadly the creaky feel is still there, so I'll take a look at the other suggestions for the cause. |
