Home > Tdi > Rear X Member replacement cost??
ManCub
United Kingdom 1991 Defender 90 200 Tdi HT Tamar Blue
Howdy folks.
I need to change my x member and am currently considering a galv x member and changing the front bumper to match.
How much would I be looking at for the job to be done?
Thanks in advance.
Mac.
Post #557394 20th Aug 2016 11:14am
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
When I had mine done I bought the part separately and found a local welder to fit. From memory the labour to fit was 250 cash which included some chassis extensions. It all depends on how bad the chassis rails are and how much steel they have to cut back to get to a sound connection point.
I was quoted £900 by a local Land Rover specialist for them to supply and fit. I would imagine that fitting a galv crossmember is slightly more time consuming as you have to grind back some of the galv to prepare and is a horrible job to weld galv metal as I'm told it spits everywhere.
Fitting the front bumper is simple just 4 bolts which you could do yourself. I imagine would be an hours labour if you took it to your local garage.
Hope that helps
Post #557448 20th Aug 2016 3:07pm
ManCub
Jrule.
Many thanks. Wye valley LR have quoted me £500 for supply and fit. I know I can get a X member for under £200 so I guess £300 for the labour seems ok. I will probably steer clear of the galvy then. 👍
Cheers for the yard stick.
Post #557457 20th Aug 2016 3:43pm
Mdm
500 is a good price
no need to bother with a galv one.
good paint and waxoyl before and after fitting will last a good time.
and no dont waxoyl the bits that will be welded or near the welded parts
Post #557461 20th Aug 2016 3:53pm
ManCub
Thank you very much.
I guess I was just trying to penny pinch and thought if I sourced the
X member myself, it may be a little cheaper.
I guess if I can throw the old girl at Wye Valley along with 500 squidleys it would save me faffing around.
I'll be using Dinitrol once done.
Cheers. Mac.
Post #557465 20th Aug 2016 4:06pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
If your replacing a rear cross member and intend to keep the vehicle then can I suggest you use Clive at Black Sheep off road.
His work is top class and a much stronger version with no mud traps, about £180 to buy + the fitting.
http://blacksheepcrossmember.co.uk
Nidge
Post #557473 20th Aug 2016 4:41pm
ManCub
Nidge.
More than happy to entertain business to a well recommended chap.
Had a look at his website and it doesn't say where he is ??
Rgds.
Mac.
Post #557487 20th Aug 2016 5:57pm
miker
He was Essex direction. Not sure whether he's currently trading unfortunately, but it's worth getting in touch.
I have one of his Crossmembers and it's fantastic.
Post #557514 20th Aug 2016 7:20pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Sadly Clive no longer makes xmembers
Post #557673 21st Aug 2016 2:01pm
Nidge
Are you sure you have your facts right ...... cause I only bought one off him at the start of the summer.
Nigel
Post #557685 21st Aug 2016 3:07pm
foxyred
hopefully I'm wrong, i'm sure the poster will confirm one way or another
Post #557698 21st Aug 2016 3:39pm
sako243
I emailed him about a month ago making a polite enquiry about prices for his cross members as I need to replace mine. To which I received the reply.
"I'm retired".
That was the entire reply. Fair enough he might be retired and fed up of people asking him but I felt it was a slightly discourteous. If he's that fed up then perhaps take down the website or put something up so people searching might find it. Also slightly odd that the reply came from a different email address, maybe his account was hacked?
Anyway, I'm thinking about the possibility of getting a similar one fabbed up by a local trailer manufacturer. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #557865 21st Aug 2016 10:13pm
miker
He has had a slightly patchy history with them ,and parts of the LR community. Before I got mine (last December) he had supposedly stopped making them. Then was making but not fitting, then making and fitting again, now apparently retired.
It's a shame as they were fantastic quality. Very happy with mine.
Might have to get friendly with someone with a press brake and brush up on my welding. There's clearly a market out there....
Post #557871 21st Aug 2016 10:26pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Fitted this - www.paddockspares.com/heavy-duty-rear-x-me...59806.html
to my 1994 300 tdi a couple pf months ago and despite being Britpart I hate to admit the quality appears excellent and the fit was perfect.
Post #560410 31st Aug 2016 11:44pm
pressbrake
United Kingdom 1990 Defender 110 Other SW Fuji White
Patchy history makes me sound crooked!
Im not interested in landrovers so the crossmembers are just a product
I make alongside my pay work at my engineering shop so sometimes I have time
To produce and at others not , a hospital job so to speak.
As far as fitting goes it depends upon my health as in 2013 I got a direct shock
across my heart and still suffer now .
Another factor with fittings is people turning up with vehicles that are really in
need of a chassis.
As far as the lr community i have customers that have become friends and there
are those like the person who phoned up at 5am to complain about a britpart xmember and im a xmember maker I should do something about it!
Post #569618 9th Oct 2016 12:10pm
