Home > Wheels & Tyres > 20mm Wheel Spacers
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
20mm Wheel Spacers
Is it possible to fit 20mm Wheel Spacers to a Defender with alloy wheels, and if so does anyone know a supplier.
30mm Wheelspacers are easy to find but will bring the tyres out beyond the Wheel arch and I want to keep them within if posssible. Confused
Post #55733 30th Jan 2011 3:01pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Rakeway engineering could probably make you a set
http://www.rakeway.com/
Post #55734 30th Jan 2011 3:29pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I think the problem with 20mm spacers is theres not enough material to hold the stud Thumbs Up
Post #55776 30th Jan 2011 7:57pm
ickle
spacers
I had 30mm spacers with boost alloys on 265 mudders and they were just within the wheelarches, I still have them if you wanted to try them on for size before buying a set. Idea
Post #55786 30th Jan 2011 8:54pm
WelshGas
Thanks for all the posts. I think "Sonic3d" is probably correct regarding the thickness being required so that strength is not compromised. And thanks for the offer "ickle". I'll probably go for the 30mm ones, when I get around to fitting them.
Thanks All. Thumbs Up
Post #55881 31st Jan 2011 10:07am
