![]() | Home > Off Topic > OK, who's correct. |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
The .gov website suggested removing the bulb ?
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
From what I have read before the bulb must illuminate to show the "self test" if this doesn't happen the tester will fail it for not functioning. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
The tester is correct.
The light must not indicate the presence of a fault. If the light itself is not functioning (which can be determined because it does not illuminate briefly when it is known that it should) then a fault exists. Quod erat demonstrandum. |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Yep, light must come on then go off. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
| Matt90 Member Since: 12 Jun 2016 Location: Leicester Posts: 142
The bulb must illuminate to allow a pass
There are probably many td5 discos running about with bulbs removed to eliminate the 3 amigos, most testers would probably not check, I can confirm this as we've been running ours for the past 3 years like this and it's never been picked up on its mot, try a different test station and you'll probably get a pass |
Although just did some research and found this
https://mattersoftesting.blog.gov.uk/commo...t-testers/ |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
Yes Matt.... Article 2
https://mattersoftesting.blog.gov.uk/commo...t-testers/ 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
| lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006
Whilst the information in the link may be correct it is from 2014, i would be wanting a bit more up to date information personally as things change. Rhubarb and custard let fly with their secret weapon.
| Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666
Further down the web page are questions and answers. It looks like if it doesn't illuminate it can't display a fault, so therefore it is rejected. As other posters have said. Here is a page from the MOT inspection manual. Click image to enlarge Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
So if the warning light stays on it will fail, if it does not come on at all it is not displaying a fault it is a pass? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Hmmmmmmm.
I am reading it as; If the light does not illuminate when ignition on it will be rejected as it cannot display a failure in the SRS, the display itself is faulty plus if it constantly illuminates it is also rejected for being at fault. That is how I interpret it. As always government docs not written comprehensively, leaving a lot for interpretation I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
