![]() | Home > Off Topic > Interesting Speed Related Article |
The kerb weight is ULW plus driver and some fuel, so you can work back to ULW from the listed kerb weight figure.
75kg "average" driver, 60kg fuel (I think it's 90% of a tank, something like that) plus a bit for oil... you're looking at something like 150kg. Someone on the forum has a rather more specific table floating around... |
Darker for some than for others... ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
This is often a topic of debate in motorhome forums. The unladen weight is of interest because its sets the speed limits in the UK whereas when you go to europe its the plated weigh eg 3.5t...where this is interesting (in motorhome world) you could take a motorhome with an unladen weight of 2t in the UK and do 70 but its plated as 4.25t so in europe its a lower speed limit!
Rather interestingly i read an article last month about the roll out of variable vehicle speed enforcement on cameras and speed vans...basically most (not all) speed cameras current are set to the road limit and are "dumb" so dont know your vehicle type. What they ![]() |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
I do wonder where our works Defenders come in, as they of course have winches, big roof rack, internal racking, night heater, massive mud tyres etc all fitted *before* you load them up with tools and kit. Quite probably the unladed weight will be over the 2040KG limit stated. I think with cherrypickers it is probably even more of a grey area. Some are registered as plant for example...others are actually quite light but I think they are still something like 2500KG before you add any payload...
I suspect they actually are subject to lower limits, but I don't think I have ever seen anyone comply with those limits in any kind of van, pickup or 4x4... 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Where was the article? The problem with this is that some things are possible and some are not. There have for years been cameras which can differentiate between HGVs and non-HGVs, for example, based on their radar signature. However it is not even now possible to differentiate between a vehicle which is a DPV and a similar one which is not by any means other than a VRN look-up (because visually there is no difference). In order for this to work, there has to be a record on someone's database that contains some information that allows a determination to be made. At present, neither the ULW nor the vehicle's C&U classification is recorded anywhere, so this cannot happen. It may be in the future this information is recorded, but it isn't now and I am not aware of any plans for it to be recorded. If it does come about it is more likely that it will be recorded for new vehicles rather than retrospectively. There is also a massive data overhead with any VRN look-up system, but with the rapid technological advance in networkmtechnologies this is no longer such an issue. So whilst there is no doubt that there are systems which can differentiate between some vehicle types, I do not believe that there are any which can identify a DPV Defender from a non-DPV Defender. |
I am sure you're right, and such a vehicle (obviously a work vehicle) is more likely to be pulled in. I also agree about compliance, it is incredibly rare to find a light commercial obeying the limits. |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
A colleague was prosecuted more than 12 months ago by a "Safety Camera" for doing 58 in a de-restricted zone - he was driving a VW Caddy which is no longer considered a "car derived van" and was therefore restricted to the lower limit. |
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 ![]() ![]() ![]() |
I suspect that the vast majority of sole trader builders,plumbers, sparkies etc have no idea that their vehicles are subject to different speed limits . The payload is just how much can I get in, if it is full use the passenger seat for extra capacity. HR064 Hampshire and Berkshire 4x4 Response
Now that (Riccarton's post above) is interesting! However "safety" camera vans usually have an operator sat in them who could presumably make the judgement.
I wonder how that actually came about. |
I can't remember or find the article tbh, too long ago I'm afraid Mike
Found it ![]() http://www.businessvans.co.uk/van-news/sma...n-drivers/ Mike |
Thank you!
The article makes it clear that it is refering to SPECS (and presumably similar) systems that incorporate ANPR and therefore rely upon VRN look-ups to the PNC or DVSA databases. Since these do not at present record DPV status or ULW I don't see that they can determine limits for ambiguous vehicles such as the Defender, though in time this may change. |
No Problem
As with all these technologies they (annoyingly)develop it...but agree, there are loads of vehicles with ambiguities or that have gaps in registration documentation etc Mike |
