![]() | Home > Td5 > Nanocom readings |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Nanocom. Plug-in worry
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6024 ![]() ![]() ![]() |
Thanks! 1999 Defender TD5 110
Sorry, not helpful I know!
People I know who plug them in, are constantly monitoring and worrying about stuff they never knew about before and their truck has always run fine (and since)! Ignorance is bliss. |
Not worried, just want to make sure the reading is correct i.e for the MAF and want to understand what the cylinder balance is all about. 1999 Defender TD5 110
I've no need talk really. I drove from Northwich in the heat yesterday afternoon and thought the 110 was down on power a little. I thought I should unplug the MAF to see if it made a difference.
A nanocom would of course give me that info, but i just put it down to 'warm air' and spannered on the v8 instead ![]() |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 589 ![]() ![]() ![]() |
AFAIK, your MAF reading seems correct to me.
Cylinder balance, I think they should all remain within the same values, ie not one going completely off range. These can fluctuate, but should remain in the 1 digit value range (either positive or negative) when idle. TB low range input, might very well be a software bug in the Nanocom, dunno if it's been fixed in a recent update, see the Nanocom forum for more info. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
I have a very old nanocom. the gray box thing and almost all switches are just the oposite from what I would expect.
![]() Your Maf reading is about right it might be a little higher, but your 3rd gear full power with high revs reading is more important, just google what it should be. cylinder balance with mine is max about 4 when running constant. If I am correct the balance is about trying to let the engine run smooth so the ecu varies or the timing or the amount off fuel it injects. Your turbo pressure is high for a Td5, so your is probably tuned. Mine peeks at 1,25 in normal mode and 1,35 with my psi power box switched on. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I do have a mild Stage 1 tune
![]() Will google for 3rd gear revs. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2286 ![]() ![]() ![]() |
I too am in the if it ain't broke don't fix it camp - ignorance can be bliss - but ignorance in my case tends to cost money
![]() That said, I do think a Nanocom would be a sound investment - albeit I would end up looking for things....... John, how are you finding it? Are you guilty of now looking for things or is it something you have under control? I must say I am tempted to buy one but I know how that story would end ![]() |
I am finding it OK. Only used it once while driving, a bit hard to look at the readings while driving.
I have a 2hr ish trip on the cards next weekend for a rally, so will be towing up and down hills and low rev work, so will be taking it with me and mate can watch the screen and see how things look. My main reason for getting it was to make sure all is well and keep eye on things and to make sure sensors are good i.e MAF being one. Once I get an idea what figures should be then I will be content, but for now I will be playing with it a bit! Trying to register with BBS as a new owner and awaiting a reply back. Then will look at latest firmware etc if needed. Another reason for buying it, if i want to get the car checked then it will cost in the region for 30-40 to get scanned, or more if paying local garage fees, now I can do it myself. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Good man
![]() Thanks for the response - yes I agree with the preventative maintenance aspect. According to a DJ earlier, it's only 18 weekends until Christmas (I know ![]() ![]() |
Maybe worth jumping on the group buy deal and getting one earlier and maybe saving some money with the offer? 1999 Defender TD5 110
Thanks for pointing me in the Group Buy direction John - I may just take the plunge
![]() Of course you are forgetting that Santa does not have to but his presents, his elves make them...... |
Please read 'buy' not 'but' ^^^^
I might get a pair of reading glasses off Santa too ![]() |
