Home > Wheels & Tyres > Spare tire
Page 1 of 3 123>
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Spare tire
Is there a rubber pad or anything that goes between the spare tire and the mount on the rear door?
Post #55687 30th Jan 2011 3:53am
leeds
Short answer is no.
Spare wheel is just 'clamped' onto the mount by three wheel nuts.
Why do you ask?
Brendan
Post #55688 30th Jan 2011 3:58am
defender75
when i close the door the tire vibrates a bit. Seems on there tight but what do I know.
Post #55689 30th Jan 2011 5:27am
leeds
If it is a swing away wheel carrier you can adjust/replace the rubber bump stops.
If fixed original I do not know
Brendan
Post #55695 30th Jan 2011 9:27am
Glynparry25
I know the answer tho that one...... get a swing away Wink Cool
Glyn Sheep
Post #55696 30th Jan 2011 9:46am
leeds
Glyn Sheep
Then we have the discussion about which swing away carrier fits with which rear bumperettes! Rolling with laughter
Brendan
Post #55702 30th Jan 2011 10:04am
Glynparry25
AGAIN!!! Shocked
Glyn Sheep
Post #55703 30th Jan 2011 10:06am
BigMike
If you have 235/85 and its doing it, take the wheel off and adjust the nuts on the lugs, ie turn them back nearer the door. then refit the wheel. Play with it til its hard up against the door.
if you have wider tyres than 235 then you cant do it as the wiper will foul on the tyre, and the vibration on door close is unavoidable
Post #55708 30th Jan 2011 10:27am
RED-DOT
That will obstruct your rear wiper if you have one. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #55724 30th Jan 2011 12:06pm
BigMike
The point is you move the adjustment nuts until the position suits/it doesnt rattle.
Post #55725 30th Jan 2011 12:29pm
defender75
I don't have a swing away. I have a 265/75/16 on the door. It doesn't make noise when I drive just I close the door it shakes a bit and it annoys me.
My last 110 was a 93 and I had a mantec on it as the oroginal door sucked and cracked all over from the weight of the door.
Post #55744 30th Jan 2011 5:31pm
BigMike
it only does it with wider tyres. mines the same. with the old 235's it didnt do it, but i can relate to how irritating it is. when you shut the door you think wtf?! its going to fall off
Post #55751 30th Jan 2011 6:35pm
defender75
I actually had it with the 235 too. HA
Post #55789 30th Jan 2011 9:15pm
BigMike
In which case, your nuts need adjusting Laughing
Post #55800 30th Jan 2011 9:29pm
defender75
are there nuts on there for sure? I have svx rims. Just wondering what is under the wheel. With the door closed if I rock the wheel it seems fine.
Post #55841 30th Jan 2011 10:50pm
Page 1 of 3 123>
