Home > Puma (Tdci) > passenger side fuse box wiring - where do they connect.
Cold_n_Wet
Norway
A mate pulled this out a couple months back while changing engine and gear box.
Its LHD - 2007 110 stw.
Which terminals do these attach to - Brown / brown with orange strip.
As he´s lives on otherside of country, he cant tell me.
Also found this loose connector, nothing really obvious missing a connector so any hints
Glen "Rafiki" 2007 110 STW - Rolling rebuild.
Post #556041 14th Aug 2016 9:00pm
ickle
I think the loose connector is central locking
If the vehicle is running and the ring terminal has no witness marks on it from a screw - is it for air con or similar heavy load that isn't fitted to your truck?
Keith
Post #556046 14th Aug 2016 9:03pm
Cold_n_Wet
Norway
They have been connected before, screws are loose in the fuse box, but its not obvious of which side.
The white connector is a bit of a mystery.
It has central locking and aircon.
Its a non runner and I hope to get it running this week.
Post #556047 14th Aug 2016 9:09pm
ickle
I'll have a look tomorrow if no one else comes forward as mines a 2007 LHD 110 station wagon with AC and CL - it should be the same!
Keith
Post #556050 14th Aug 2016 9:13pm
VeeTee
Netherlands
According to the Wiring Diagram, page 7, brown wire w/ orange stripe is for a heated rear screen. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #556053 14th Aug 2016 9:18pm
Cold_n_Wet
Norway
Thanks Keith "Rafiki" 2007 110 STW - Rolling rebuild.
Post #556054 14th Aug 2016 9:19pm
Cold_n_Wet
Norway
Well the mystery of the white connector is solved, it was dangling underneath the wagon and hadden been put in when the seat box was put in, so seat box out again and put in place and connected up.
Now to find out which side of fuse box these two wires go..
might have her running before the weekend Smile "Rafiki" 2007 110 STW - Rolling rebuild.
Post #556429 16th Aug 2016 1:46pm
ickle
White connector is central locking, out of the back of the seat box and up the B post.
Without stripping the fuse box out you can't actually see where the wires go to - I shoved the phone under the box and took a few photos.
Stood in the door, looking towards the rear of the truck the brown and white goes into the second fuse from the back on the right hand side, the rearmost cable is brown pink and the third is brown red, once I've found my cable i'll try and post the picture.
HTH Keith
Post #556513 16th Aug 2016 7:40pm
ickle
Post #556518 16th Aug 2016 7:54pm
Cold_n_Wet
Norway
Thanks Keith,
Could you take a picture inside the fuse box at the very back, where the thick brown / thin Brown - Orange comes in ?
These two fix on to the terminals at the back toward the rear of the fuse box.
Glen Thumbs Up
Post #556547 16th Aug 2016 10:20pm
ickle
Hi Glen,
Unfortunately all I can photograph is the black insulation - you cannot see the wiring colour from the top.
If you're still stuck I can remove more stuff 7/or fuses at the weekend for a clearer view
Keith
Post #556811 17th Aug 2016 10:16pm
Cold_n_Wet
Norway
That was a good photo, and all is now connected up as it should be (I hope).
Thanks
Post #556911 18th Aug 2016 11:25am
dorsetsmith
brown cable from battery go to conman link in the fuse box and the other cable is power to second fuse box through 100 amp fuse link
Post #556917 18th Aug 2016 11:41am
